Post by glennz01 on Aug 16, 2014 12:15:46 GMT -5
I was wondering if you needed to replace only the rubber or nylon on a drive shaft for a thumblers tumbler AR-12 if this would be possible... i see the rubber and nylon is sold separate but i cant figure out how to get the old rubber off.
If anyone knows how please let me know... i can't find any vids on it but i see that the rubber is sold for that purpose.
Post by connrock on Aug 17, 2014 9:23:28 GMT -5
Replacing both the rubber and nylon would depend on how much each is worn. I'm not familiar with the AR-12 and am wondering what the 3rd roller on the middle of the shaft is for?After looking at photos of the tumbler it doesn't seem to me that the middle roller is needed? The replacement rollers are sold here,,,, rollers and it wouldn't be very expensive to replace all of them? I'll let someone with experience removing the old rollers on the AR-12 help you but if no one does I'll try to help. connrock
Post by glennz01 on Aug 17, 2014 11:33:32 GMT -5
Replacing both the rubber and nylon would depend on how much each is worn. I'm not familiar with the AR-12 and am wondering what the 3rd roller on the middle of the shaft is for?After looking at photos of the tumbler it doesn't seem to me that the middle roller is needed? The replacement rollers are sold here,,,, rollers and it wouldn't be very expensive to replace all of them? I'll let someone with experience removing the old rollers on the AR-12 help you but if no one does I'll try to help. connrock They are fairly warn down, the nylon ones aren't warn down much but the rubber ones are warn down enough to make the tumbler barrel not spin as fast as it should. The middle roller is only used if you put ether two 6 or 9 lb barrels on.
charles kuchar
Member since November 2010
Post by charles kuchar on Aug 17, 2014 15:13:47 GMT -5
i have two thumbler tumblers and keep spare shafts. they are not very expensive but if you have lots of time, order the parts to change the rollers. chas
Post by glennz01 on Aug 17, 2014 22:57:59 GMT -5
I will be going to where my tumbler is running tomarrow, i will see if i can at least turn the rollers over and get another years worth out of em.
Today I just ordered a Graves 6 wheel cabbing unit I don;t have much jewerly worthy stuff now (a few things) but i hope to get a lot soon.
