bcrockhound
Member since June 2014
Post by bcrockhound on Aug 20, 2014 14:50:27 GMT -5
Hello,
I am looking to rent a cement mixer in the next while to see how that tumbles rocks. The Lortones are not enough for all the rocks I have, and I'd like to be able to throw the bigger/junkier pieces in a big tumbler. Has anyone had experience using a cement mixer to tumble rocks?
I've seen some homemade tumblers on this forum and they look great, but I am not the best handyman. What plus-size tumbling equipment do you guys use?
Thank you.
Post by snowmom on Aug 20, 2014 14:57:49 GMT -5
now there's an example of thinking outside of of the box... this gang is creative enough you should get quite a few good ideas... have you looked at the back posts for the home made equipment thread? totally inspiring! Bet some of the folks here could talk you through creating a high capacity setup. The combined knowledge of the people on this board and their willingness to share and help others is truly astounding!
bcrockhound
Post by bcrockhound on Aug 20, 2014 15:04:23 GMT -5
now there's an example of thinking outside of of the box... this gang is creative enough you should get quite a few good ideas... have you looked at the back posts for the home made equipment thread? totally inspiring! Bet some of the folks here could talk you through creating a high capacity setup. The combined knowledge of the people on this board and their willingness to share and help others is truly astounding! I have and I agree! To the chagrin of my auto shop owning Dad who wishes he had a son to take over his business, I was born with my mother's brain, which struggles with do-it-yourself tasks, haha. But I'm game to try given the time and instruction. The generosity and helpfulness of the members of this forum is astounding indeed. It's just great to see so many people interested in rocks. I bring it up with anyone in my normal life, it's like I'm talking about aliens.
Post by snowmom on Aug 20, 2014 15:05:39 GMT -5
wonderful when you find your own kind, isn't it?
Post by deb193redux on Aug 20, 2014 15:19:04 GMT -5
I don't think it turns fast enough. But it has a large diameter to get a long slide, which is where the work happens. So, it may just take longer. The basic design is used one Covington tumbler, It may also be subject to drying gout, and difficult to clean between grits. Not easy to have a different barrel for each stage. People have also put 5gal buckets on a motor PVC might last a little longer then plastic buckets: forum.rocktumblinghobby.com/thread/4197
bcrockhound
Post by bcrockhound on Aug 20, 2014 15:35:37 GMT -5
Thanks a lot for that, Deb. Those are great ideas and look pretty simple. I would like to use the more professional tumblers for the further polishing stages, but a big brute force one to knock rocks down and smooth them up a bit would justify more rockhounding, ha.
Post by quartz on Aug 20, 2014 23:51:00 GMT -5
I built one very similar to the one above using the angled 5 gallon bucket, but used 12" P.V.C. for the barrel; had to try it. Made it adjustable from 30 to 45 degrees angle and run it about 25 R.P.M. The first time I loaded it with some fairly large really blocky mtl. All the rocks held hands with each other, and the more I put in, the less movement I had. Second load was a bunch of pretty small rounded stuff, tumbled great. I think the angled barrel idea is best suited to fairly round, like water worn, rather than blocky, rough-edged things. I tumble our big rough rocks in a horizontal 5 gallon barrel set made of 12" P.V.C. pipe, each a foot long. Have a barrel for each stage, and run 2 at a time.
1nickthegreek
Member since February 2014
Post by 1nickthegreek on Aug 21, 2014 1:57:35 GMT -5
Hello, I am looking to rent a cement mixer in the next while to see how that tumbles rocks. The Lortones are not enough for all the rocks I have, and I'd like to be able to throw the bigger/junkier pieces in a big tumbler. Has anyone had experience using a cement mixer to tumble rocks? I've seen some homemade tumblers on this forum and they look great, but I am not the best handyman. What plus-size tumbling equipment do you guys use? Thank you. Get in touch with jamesp, he builds all sorts of massive scale tumblers including one with old farm equipment tires and wheels as drums if I remember correctly.
Post by jamesp on Aug 21, 2014 6:11:34 GMT -5
Use barrels of some sort. Cement mixers are made to mix, too violent. Tires to violent. Figure out a large cylindrical barrel that has about the same scale as a regular tumbler. Steel works great. Many big tumblers I see use steel barrels. If I was tumbling a lot of material I would make like 8 foot shafts and put a bunch of 8 inch diameter barrels on it. Single heavy barrel is heavy. HEAVY. Larry(quartz) chined in above. He is up to 12 inch barrels. He could probably kick our arses if he handles those w/out a crane.
blessed
Member since January 2010
Post by blessed on Aug 21, 2014 12:31:12 GMT -5
Hello bcrockhound and every one else. I have also thought about using a cement mixer. Been mixing cement for a few day in one. Mine runs at 28 RPM. Mine has three steal blades for mixing so there would no slide and roll. Might have to give it a try after I get all these concrete blocks laid. If I do I will let everyone know. Have a good day. James
Post by Starguy on Aug 21, 2014 19:28:18 GMT -5
My advice is to bite the bullet and buy a 40 lb tumbler. At that size, you need to have some flat sides in the barrel. Small <3 lb round tumblers are about the max for round barrels. I think a cement mixer drops the rocks too much and you will get cracks and spalls. SiC grit would wear steel barrels out really fast too.
Post by jamesp on Aug 21, 2014 21:52:42 GMT -5
My advice is to bite the bullet and buy a 40 lb tumbler. At that size, you need to have some flat sides in the barrel. Small <3 lb round tumblers are about the max for round barrels. I think a cement mixer drops the rocks too much and you will get cracks and spalls. SiC grit would wear steel barrels out really fast too. Cement mixer will make a mess out of your rocks. I agree. Seen it done.
bcrockhound
Post by bcrockhound on Aug 21, 2014 22:08:59 GMT -5
Thanks very much, everyone. Glad I got this advice before renting the mixer. Interested to see how your experience goes, blessed. The homemade tumbler ideas are great, and I think within my technical capabilities. I really appreciate the detailed advice!
Post by deb193redux on Aug 22, 2014 0:42:22 GMT -5
I didn't know you meant rental. No way on cost alone. If you had an old mixer and wanted to try to get speed and load right, that is one thing. But the rough grind is still going to take 4+ weeks, and the rental would add up real fast. Most people rent equipment for a day or two.
Post by jamesp on Aug 22, 2014 7:36:38 GMT -5
This wood based tumbler runs like a charm. It had a 50 pound PVC barrel for years. One inch solid shafts. Parts all from Industrial Surplus in Lincoln, Nebraska. Uses a 1/8 HP 1075 RPM A/C fan motor. 2 inch motor pulley and 12 inch big pulley. 3/4 inch shaft would suffice. I think I have $140 in it. Quiet wood frame easy to make.
Post by jamesp on Aug 22, 2014 7:43:24 GMT -5
This tumbler absolutely destroyed every rock I put in it. Hole was sealed by inflating an exercise ball into opening. laughing
Post by jamesp on Aug 22, 2014 7:49:10 GMT -5
Same tumbler as above but modified to reality. love this tumbler. Back shafts run fast for coarse. Front shafts run slow for finish and sensitive materials. Metal a pain in the arse, wood frame is fine. (over)Built out of junk from boneyard. Three 16 pound barrels and one 50 pound barrel. Will work your arse off.
luvtogrow
Member since November 2012
Post by luvtogrow on Aug 22, 2014 8:20:41 GMT -5
Friend here in town tried a cement mixer to tumble poppy jasper. Turned into dust and gravel.
Post by connrock on Aug 22, 2014 8:33:08 GMT -5
James,,,I never understood the theory of using a big tire for a tumbler barrel.It seems to me to be totally against the way the rocks are supposed "tumble" on top of each other and not just fall on top of each other. The tumbling action in a "normal" barrel occurs just as the rocks come up to about the top of the barrel and "slide" down on top of each other,,sort of like a wave cresting on a shore. With the tire tumblers the center is sealed off and I "think" some of the rocks carry over the top and crash down onto the top of the other rocks at the bottom of the tire????This would be especially true if the tire was filled with too many rocks. What say you? connrock
Post by jamesp on Aug 22, 2014 19:48:43 GMT -5
It was too rough on the rocks. They bounced a lot, sounded like an avalanche.
