Post by kap on Jun 19, 2007 18:33:20 GMT -5
I am setting up my tumblers and need some info on how much grit to use. I have course , medium , fine , pre polish , and polish. The grit I have is in bulk containers. Here are the drums I have. THANKS!! Keith Also on agate and quartz how long in each stage?
Post by deb193 on Jun 19, 2007 20:39:18 GMT -5
www.therockshed.com/instructions1.html#Rotarythose look like 12 or 15 lb barrels. Follow the chart at first. If you have a lot left after a week, yet you did get thick mud, then you can cut back. If it is all gone after 3-4 days and slurry is thin, you need a bit more. You can dump the slurry on some concrete and gently put water to wash the mud. If you see dark grit left, you know it did not all get used up.
Post by Bikerrandy on Jun 19, 2007 20:43:09 GMT -5
Also, don't pour the slurry down the drain!! It will turn into cement inside the pipes.
earthdog
Don't eat yellow snow
Member since June 2006
Post by earthdog on Jun 19, 2007 20:59:19 GMT -5
Man, thats too big of a set-up for a beginner. I think you should ship it to me and in return I'll send you a couple 3# tumblers.... BTW, welcome to our home..
Post by kap on Jun 19, 2007 21:36:36 GMT -5
THANKS!! I love this site! Keith
darrad
Member since September 2006
Post by darrad on Jun 19, 2007 22:02:48 GMT -5
What kind of rock are putting in those? Watch the mixing of different hardness.
WarrenA
Member since November 2003
Post by WarrenA on Jun 19, 2007 22:22:41 GMT -5
Is there a rubber sleeve of some type over the shafts? I am going to be making a simular tumbler in the near future. I hadn't considered using a chain to drive the rest of the shafts but I could work that out HMMMM
Post by catmandewe on Jun 19, 2007 23:41:30 GMT -5
Now thats a tumbler!!! Need to put a turbo'd 350 on that, (in my best tim allen voice) ARGGGGH ARRRGH AARGGGGGGHH!!
Looks like you better be lookin into buyin grit in the bulk 55 gallon drums. Welcome to the site, lotsa nice people here.
fossilman
Member since April 2007
Post by fossilman on Jun 20, 2007 8:27:33 GMT -5
that's the tumbler set up I want! What's the HP of the motor on it? I've been designing one very similar to that, even with the chain drive.
fossilman
Post by fossilman on Jun 20, 2007 8:29:15 GMT -5
I think those are 20 pounders or larger, the top ones may be 40 pounders. Even the small one has the bolt tops.
Post by kap on Jun 20, 2007 20:58:48 GMT -5
It has a 1/3 hp motor and it has rubber sleeves on the shafts. I also have 2 drums that are twice as big as the ones in the picture. I got the 16in saw going today and cut some picture jasper ;D it cuts sweet. Keith
JEFFD
Member since December 2004
Post by JEFFD on Jun 20, 2007 21:49:56 GMT -5
As a general rule one heaping Tablespoon full of grit for each pound of rock will give a good slurry.
That should wear out in a week...Then it is time to do it again. You will want to run a least two or more weeks in course. After course run your other grits about 7-10 days.
Polish should be about a heaping teaspoon full...let it run for a week or two.
Others here have recipes that work great. I usually run mine through the vibe after course.
