sak
Member since December 2013
Post by sak on Sept 10, 2014 12:05:09 GMT -5
Hi All,
Typically, my slurry in rough stage (using a rotary tumbler) gets thick after about 2-3 days. I just did a clean out and fresh re-charge on my rocks (in rough stage 80 grit) and I added some tried slurry chunks to the mix. It seems to have worked - in that it made my slurry thicker faster than otherwise.
Do you guys also do this, and have you experienced the same results?
Thanks for all your thoughts.
Sak...
Post by jamesp on Sept 10, 2014 13:41:20 GMT -5
it will really do that with soft rocks. Not on agates or quartz minerals. If you are tumbling w/just grit + water + rocks. Yes, adding dried slurry will thicken the slurry. I add soft limestone to do the same thing.
blessed
Member since January 2010
Post by blessed on Sept 10, 2014 20:10:16 GMT -5
I have used dried slurry before, it works, and I have used kitty litter. James
tkvancil
Member since September 2011
Post by tkvancil on Sept 11, 2014 9:31:16 GMT -5
I haven't tried it but some folks swear by it. I go with a minimum amount of water and get a good slurry fairly quickly. Might try it some day to see if there's any difference.
