charles kuchar
Member since November 2010
Post by charles kuchar on Oct 6, 2014 6:45:14 GMT -5
vibration but it still runs ok. does anyone have experience in running their noisy lotto's? I got a new motor from the rock shed but am interested in how long the noise motor will keep working so I haven't changed the motor yet. chas
Post by connrock on Oct 6, 2014 8:00:56 GMT -5
I've only had 1 motor burn out on one of my Lot-O's and when it died,,,it just died. If yours is making a noise I would imagine it's the bearings so when they seize up the motor will more then likely get hot an shut down. My motor ran just about all the time for about 10 years.How long has your motor been in use? connrock
Post by orrum on Oct 6, 2014 8:49:29 GMT -5
The bolts will get loose in the motor and mine broke the frame from rhe excess vibration and then threw the sludge and rocks everywhere plus the fans hit stuff and broke up! What a wreck. So stop now and check the bolts in the motor and also for broken springs too.
charles kuchar
Post by charles kuchar on Oct 7, 2014 6:34:06 GMT -5
the noisy one has been running for about 3 or 4 years. I have replaced a motor on another lotto I bought from a friend. it ran a few weeks and then the motor burned out. it has been quiet since I replaced the motor last fall. I did check the connections from the motor to the frame and I don't see any broken springs. I have replaced springs in the past and have spares on hand. chas
Post by Deleted on Oct 7, 2014 6:56:14 GMT -5
The bolts will get loose in the motor and mine broke the frame from rhe excess vibration and then threw the sludge and rocks everywhere plus the fans hit stuff and broke up! What a wreck. So stop now and check the bolts in the motor and also for broken springs too. mine did as well,broke the frame of the lotto in 3 places,nothing that a few passes with the heliarc welder couldn't fix. Dave.food for thought.someone needs to fabricate a single barrel 15 lb lotto
Post by connrock on Oct 7, 2014 7:27:06 GMT -5
The Lot-O frames are guaranteed for life. One of my frames cracked and I sent it back.They sent me a new frame mounted on a new board. connrock
Post by jamesp on Oct 7, 2014 7:50:38 GMT -5
The Lot-O frames are guaranteed for life. One of my frames cracked and I sent it back.They sent me a new frame mounted on a new board. connrock Spilt slurry wiped out the bearings on a 1/3 HP motor on my rotary tumbler after 2 years. 10 years is unheard of for a tumbler motor. Seems like 3 years is a long time.
Post by Jugglerguy on Oct 7, 2014 12:07:55 GMT -5
My Lot-O is only about three years old, but I only run it about every month or two, so it hasn't had much use. Mine has started to make a louder vibration noise at times, but other times it's just as quiet as ever. I've tried to find where the vibration noise is coming from, but everything seems tight and the springs aren't broken. It's not real loud, but I notice the difference.
1nickthegreek
Member since February 2014
Post by 1nickthegreek on Oct 7, 2014 18:25:09 GMT -5
I just broke a spring when my fans were hit and knocked out of sync,one weight at 6 PM and the other at 10 PM, talk about some crazy vibrations LOL Damn thing was doing circles on the floor However, I was on the phone with Tom (the manufacturer) at the time of discovery and he said he was going to pop a spring kit in the mail to me that day so hopefully will have a freshly "sprung" Lot-O-Tumbler in the next few days.
Post by connrock on Oct 8, 2014 7:10:15 GMT -5
James I think it's the luck of the draw with these small motors especially today when a lot of them are made overseas. Some are shot in no time while others take a lickin and keep on tickin. connrock
Post by connrock on Oct 8, 2014 7:12:35 GMT -5
Jugglerguy,,,A light load will make the unit sound a lot different then if it's loaded properly. This can happen when using a lot of ceramic media as the media doesn't weight the same as that amount of small rocks does. connrock
Post by Jugglerguy on Oct 8, 2014 15:51:11 GMT -5
Connrock, I've had it happen with the same load from one day to the next. It may be that it's more likely to happen with a light load though. I always fill it up, but I hadn't thought about the ceramic being lighter.
1nickthegreek
Post by 1nickthegreek on Oct 9, 2014 2:49:12 GMT -5
Hey Jugglerguy, do you weigh your loads out, or just do like I do on the obsidian and stuff the barrel with ceramics then add the however many pieces of Ob that you are running at the time to the top of the barrel?
Post by Jugglerguy on Oct 9, 2014 12:37:22 GMT -5
I never weigh any of my rocks. I put the rocks in the Lot-O barrel and then add ceramics to fill it up.
charles kuchar
Post by charles kuchar on Oct 9, 2014 19:53:44 GMT -5
I have ceramics that I use in my tumblers. I have plenty of rocks to fill the lot-o. what benefit would I get using ceramics and less rocks? or what step in the polishing process should I use the ceramics. I am using ceramics in my polishing process in the tumblers so that the rocks don't get chipped on the edges because of falling together. the ceramics certainly help in that situation. chas
1nickthegreek
Post by 1nickthegreek on Oct 9, 2014 20:10:31 GMT -5
I never weigh any of my rocks. I put the rocks in the Lot-O barrel and then add ceramics to fill it up. Same here LOL Just gotta fill that barrel as full as ya can with the obsidian and it comes out so beautifully!!!!!
Post by connrock on Oct 10, 2014 8:33:05 GMT -5
Charles,,,the reasons for using ceramic media is,in some cases,to help cushion the load and another reason is so that the ceramic media gets onto every surface of the rocks being polished or ground with grit. The more "surface contact" you have the more the grit/polish will be in contact with the rocks you're doing. When ceramic media is used as a "filler" it helps the rocks from not hitting each other,causing chips.etc,and "cushions" the load. connrock
