hbonly
Member since December 2012
Post by hbonly on Oct 6, 2014 19:05:44 GMT -5
Hello. my question is....when I go to the final polish stage of polishing...using the above...should I remove the ceramic pellets that I've been using in stage 1 and 2? No, I don't have a second, seperate bowl for polishing (yet). All I can do is scrub the hell out of the one I have. This I have done. I do not have plastic pellets. Would this help me with only the one bowl? Or....no media at all?
Thunder69
Thunder 2000-2015
Post by Thunder69 on Oct 6, 2014 21:36:42 GMT -5
Thorough cleaning is a must ..so is ceramic media in a polish stage..A different set of ceramics for just the polish stage is best..plastics are not a very good media in a vibe...As Obi says "Use the ceramics Luke"LOl...Best of luck..Post pics when done to show off your pretties...John
Post by braders on Oct 6, 2014 22:54:34 GMT -5
I love my uv 18 and have never used a filler !! Always keep it full have a batch of small filler rock you use over and over no matter what it is ....just avoid rough edges after your medium grit as for rest of by the books ....I break most those rules to and end up with a lovely shine !! Never used a dedicated polish drum in roto or vib as well , I know this will bring a huge argument but I swear its a sales pitch lol
Post by braders on Oct 6, 2014 22:57:40 GMT -5
Forgot I tried a plastic bead filler once and hated it !! Couldn't get the smooth flow outta my vib from it ?? The soft damper of it maybe ?? Just keep it full
Post by Deleted on Oct 7, 2014 4:04:48 GMT -5
Greetings [hbonly] firstly may i welcome you back to RTH Forums from the other side of the pond! Ceramic media that moves with the rock through the stages can and should be used instead of new ceramic media as the new ceramic media can have uneven and rough edges, which can ruin your entire batch. Please check out my Sticky's below. -- Please click images to open larger images in a new Tab, same with everything that is Underlined! I currently have a 3lb Beach (UK), Lortone QT 12/66 (USA) rotaries & 2x Viking Vibrasonic (Diamond Pacific) (USA) virbrating tumblers, with Silicon Carbide grit F80, F220, F600, F1200, with Tin Oxide (1.0 micron) & Aluminum Oxide (1.0 micron & 0.3 micron) polishes. I hail from (The Barony of Seabegs) Bonnybridge, Stirlingshire, U.K, where aliens (15mb) sometimes come for a visit & about 4 miles west from that monstrosity & 7 miles west of this new monstrosity! Sticky's: their contents are resource information 1#: Vendors worldwide (2mb), 2#: How to use the forum, 3#: How to identify rocks & minerals, 4#: Save money on expensive grits & polishes, 5#: Aussie Lapidary Forum: Rock Tumbling Guide!
Post by Deleted on Oct 7, 2014 6:13:03 GMT -5
Having a dedicated bowl for polish is not a sales pitch.i have done some pretty extensive tests on that.viewing the results under magnification.it all depends on how rich of a shine you want.also plastic pellets are for rotary tumblers. Dave
Post by braders on Oct 7, 2014 7:12:37 GMT -5
Having a dedicated bowl for polish is not a sales pitch.i have done some pretty extensive tests on that.viewing the results under magnification.it all depends on how rich of a shine you want.also plastic pellets are for rotary tumblers. Dave On the magnification thing ...have ya done any looking at different grits , or added stages of grit sizes ? Iv been very curious on that topic Iv never looked at mine under anything other then eyes , so guess I cant argue the bowl thing .
tkvancil
Member since September 2011
Post by tkvancil on Oct 7, 2014 10:27:01 GMT -5
The ceramics used in previous stages can be moved along with the rocks to polish in your UV18. Clean them with your rocks by whatever method you happen to use. No plastic in a vibe. If you haven't seen this yet it is worth checking out. Lots of good info. forum.rocktumblinghobby.com/post/337618/threadAs for a separate bowl or barrel ... No scrubbing and no worries about cross contamination from embedded grit.
Post by catmandewe on Oct 7, 2014 10:55:36 GMT -5
If you must use filler then go to your local body shop and get a bucket full of broken safety glass, then tumble them until they are round and have no more sharp edges. These can then be used as filler in any stage you want provided you clean them good. They are pretty cool looking too!
I dont use filler anymore, just rock.
Tony
hbonly
Post by hbonly on Oct 8, 2014 17:35:47 GMT -5
THANK YOU for your replies. Helped tremendously. Will post pix from this batch. ONE more question.... how full is full? What is a good benchmark? I've heard that less than 3/4 full is bad. Why? is too full better than underfull?
Post by Deleted on Oct 8, 2014 17:40:51 GMT -5
Greetings [hbonly] 99-100% full it is a vibe not a rotary! My YouTube videosPlease check out my Sticky's below. -- Please click images to open larger images in a new Tab, same with everything that is Underlined! I currently have a 3lb Beach (UK), Lortone QT 12/66 (USA) rotaries & 2x Viking Vibrasonic (Diamond Pacific) (USA) virbrating tumblers, with Silicon Carbide grit F80, F220, F600, F1200, with Tin Oxide (1.0 micron) & Aluminum Oxide (1.0 micron & 0.3 micron) polishes. I hail from (The Barony of Seabegs) Bonnybridge, Stirlingshire, U.K, where aliens (15mb) sometimes come for a visit & about 4 miles west from that monstrosity & 7 miles west of this new monstrosity! Sticky's: their contents are resource information 1#: Vendors worldwide (2mb), 2#: How to use the forum, 3#: How to identify rocks & minerals, 4#: Save money on expensive grits & polishes, 5#: Aussie Lapidary Forum: Rock Tumbling Guide!
tkvancil
Post by tkvancil on Oct 9, 2014 1:31:28 GMT -5
THANK YOU for your replies. Helped tremendously. Will post pix from this batch. ONE more question.... how full is full? What is a good benchmark? I've heard that less than 3/4 full is bad. Why? is too full better than underfull? I've got a UV18 but only been able to run it three times. Not enough roughing capacity yet. First two batches pretty good. Filled like the directions said, just above the center line represented by the blue stripe. Third batch got a fantastic shine. Filled level to the top of the center cone as per advice from members of RTH. It will be nearly full when using the cone as a guide.
