emyhro40480
Rockhounding since I was knee-hi to a grasshopper.
Member since October 2014
Post by emyhro40480 on Nov 16, 2014 11:00:02 GMT -5
Quick question here. I have been using Cerium Oxide polish for my quartz rocks in the polishing stage. I went to use some on a new batch I am doing and I was out. I have some Aluminum Oxide Polish and threw that in. But I also have Tin Oxide Polish, Which is better or does it matter. Moh's scale 7 on the quartz. Thanks for the help. Ed M.
Post by Deleted on Nov 17, 2014 1:25:05 GMT -5
Greetings [emyhro40480] Ed firstly may i welcome you to RTH Forums from the other side of the pond! If polishing Chalcedony, Glass and or Quartz groups virtually any polish works. Please check out my Sticky's below. -- Please click images to open larger images in a new Tab, same with everything that is Underlined! I currently have a 3lb Beach (UK), Lortone QT 12/66 (USA) rotaries & 2x Viking Vibrasonic (Diamond Pacific) (USA) virbrating tumblers, with Silicon Carbide grit F80, F220, F600, F1200, with Tin Oxide (1.0 micron) & Aluminum Oxide (1.0 micron & 0.3 micron) polishes. I hail from (The Barony of Seabegs) Bonnybridge, Stirlingshire, U.K, where aliens (15mb) sometimes come for a visit & about 4 miles west from that monstrosity & 7 miles west of this new monstrosity! Sticky's: their contents are resource information 1#: Vendors worldwide (2mb), 2#: How to use the forum, 3#: How to identify rocks & minerals, 4#: Save money on expensive grits & polishes, 5#: Aussie Lapidary Forum: Rock Tumbling Guide!
emyhro40480
Post by emyhro40480 on Nov 17, 2014 6:41:58 GMT -5
Thank you and I will check out some of the items listed. Nice resources.
Post by jamesp on Nov 17, 2014 7:57:08 GMT -5
AO will sure put the shine on the quartz. Not a thing wrong with it.
Henry
Post by Henry on Nov 17, 2014 8:00:05 GMT -5
Tin oxide, i've learned, works REALLY well on a lot of stones...but it is expensive. I usually reserve it for my favorite stones or softer jade nephrite. With aluminum oxide, I use 1000 as an "extra step" for softer stones...to help the polish along.
Post by pghram on Nov 17, 2014 9:01:44 GMT -5
I use Tin Ox & reuse it, so cost isn't an issue. I use tripoli as a pre-polish. I know a lot of folks here us AO with excelent results.
Rich
tkvancil
Member since September 2011
Post by tkvancil on Nov 17, 2014 11:15:49 GMT -5
I've used AO polish on quartz and agate, etc. with excellent results.
emyhro40480
Post by emyhro40480 on Nov 17, 2014 19:39:43 GMT -5
Thank you all for those responses. I can rest assured you guys know what you are talking about.
Ed M.
Henry
Post by Henry on Nov 19, 2014 16:50:23 GMT -5
pghram: Re-use T.O. ...great idea. How many times can you re-use it?
emyhro40480
Post by emyhro40480 on Nov 19, 2014 17:06:59 GMT -5
I'm not really sure, pghram is the one that re-uses it. You can check with Rich from above post.
emyhro40480
Post by emyhro40480 on Nov 19, 2014 17:08:34 GMT -5
Oops, sorry, you posted your response to him already.
Post by Deleted on Nov 19, 2014 17:44:17 GMT -5
RE: Re-using polish
Polish is just a grit, that is super fine. If it breaks down like larger grits then what you are left with is finer polish. There will be a minimum size. That may be the size you bought it at. Experimentation will tell.
Post by pghram on Nov 21, 2014 10:45:25 GMT -5
pghram: Re-use T.O. ...great idea. How many times can you re-use it? I don't know because I have never hit any limit. I do occasionally add a little new to the barrel because you do loose some in the process. If anything it seems to work even better, but that may be my imagination ;>) Rich
Post by Deleted on Nov 23, 2014 18:51:16 GMT -5
I doubt it's your imagination. Seems to me use makes it finer and the re-use makes it better. You observation seems to confirm.
