emyhro40480
Rockhounding since I was knee-hi to a grasshopper.
Member since October 2014
Post by emyhro40480 on Nov 30, 2014 11:59:40 GMT -5
Hello all. I recently picked up some Ceramic media from The Rock Shed but have never used this type. Do I use it in all stages and how much to use. Any information on this product would be greatly appreciated. Thank you,
Ed M.
tkvancil
Member since September 2011
Post by tkvancil on Nov 30, 2014 12:23:00 GMT -5
Generally used as filler / smalls in a vibratory tumbler. Can also be used in a rotary as the same. Be aware that if used in the coarse grind it will wear away a lot faster. I used to use it in my rotary tumblers. Would let it go a week or two in coarse so it was rounded, but not worn way down. Then when was doing the following stages I'd add it along the way to keep volume up.
What's nice about it is it doesn't hold grit like plastic pellets. You can wash it and use it in all stages rotary or vibe.
