meviva
Member since July 2013
Post by meviva on Dec 13, 2014 18:12:33 GMT -5
Hi, I have an ultra vibe 10mb. The bowl capacity is 4 lbs. I just bought an extra bowl for polish only. The problem is that I can't secure the top with the washer and wing nut. The center screw is not long enough. This bowl is just a little taller than the other one. I can secure it with just the wing nut but no washer. Will that be ok? Is there a way to make the center screw longer? I tried to turn it but it didn't turn. Can a longer replacement be purchased.
Thanks, Andrea
Post by Deleted on Dec 13, 2014 23:16:47 GMT -5
Greetings [meviva] Andrea you may find this thread useful "Replacing the threaded shaft on a UV10 w/ pics". Please check out my Sticky's below. -- Please click images to open larger images in a new Tab, same with everything that is Underlined! I currently have a 3lb Beach (UK), Lortone QT 12/66 (USA) rotaries & 2x Viking Vibrasonic (Diamond Pacific) (USA) virbrating tumblers, with Silicon Carbide grit F80, F220, F600, F1200, with Tin Oxide (1.0 micron) & Aluminum Oxide (1.0 micron & 0.3 micron) polishes. I hail from (The Barony of Seabegs) Bonnybridge, Stirlingshire, U.K, where aliens (15mb) sometimes come for a visit & about 4 miles west from that monstrosity & 7 miles west of this new monstrosity! Sticky's: their contents are resource information 1#: Vendors worldwide (2mb), 2#: How to use the forum, 3#: How to identify rocks & minerals, 4#: Save money on expensive grits & polishes, 5#: Aussie Lapidary Forum: Rock Tumbling Guide!
tkvancil
Member since September 2011
Post by tkvancil on Dec 14, 2014 1:39:36 GMT -5
Thanks, Andrea I've got the UV18 and there is quite a bit of bolt that is above the bowl and lid so I'm a bit puzzled about your 10mb. It's pretty new is it not? Try contacting the seller or thumlers before trying to get a longer shaft. I've heard the people at thumlers are pretty good to deal with. If you bought from the rock shed they're very helpful. EDIT TO ADD ... check that the new bowl goes down all the way onto the foam rubber pad. Just thought that maybe the hole could have some flash in it and might hang up on the threads of the rod therefore not going all the way down.
meviva
Post by meviva on Dec 14, 2014 11:57:33 GMT -5
Thanks Andrew that will be helpful if I have to replace the shaft. Too bad there is not an easier fix. Andrea
meviva
Post by meviva on Dec 14, 2014 12:18:58 GMT -5
I've got the UV18 and there is quite a bit of bolt that is above the bowl and lid so I'm a bit puzzled about your 10mb. It's pretty new is it not? Try contacting the seller or thumlers before trying to get a longer shaft. I've heard the people at thumlers are pretty good to deal with. If you bought from the rock shed they're very helpful. EDIT TO ADD ... check that the new bowl goes down all the way onto the foam rubber pad. Just thought that maybe the hole could have some flash in it and might hang up on the threads of the rod therefore not going all the way down. Ken, Yes it is new. I got the 10mb in October and have only run a couple of batches in it since I was waiting for the polish only bowl. It came last week. Here is a picture of the top secured only with the wing nut. As you can see there is no room for the washer. It's been running all night this way and seems to be ok. I just don't want it to damage the bowl by not using the washer..…it has to be there for a reason. I'll make a phone call tomorrow to see if anything can be done. I took the bowl off and put it back on, it seems to be sitting on the rubber pad the way it's supposed to. Thanks, Andrea
Post by MrP on Dec 14, 2014 12:49:34 GMT -5
The cover for my older UV18 bowl is different then the cover for the newest bowl I have. Is the newer cover shaped different the one that came with the UV!0?.........MrP
meviva
Post by meviva on Dec 14, 2014 13:03:21 GMT -5
The cover for my older UV18 bowl is different then the cover for the newest bowl I have. Is the newer cover shaped different the one that came with the UV!0?.........MrP The cover looks a little different. I just swapped the new top with the old top and I'm able to put the washer on. I just had a thought. I tightened the wing nut tighter hoping it will compress the foam around the edge of the cover and maybe then I can use the washer. Thanks, Andrea
tkvancil
Post by tkvancil on Dec 14, 2014 15:04:52 GMT -5
Just guessing about the washer ... mine has rubber glued to the side that goes against the lid. Probably serves two purposes. Cushion so the nut does not wear into the plastic of the lid and as sort of a lock once it's all tightened down. Again just guessing but it is probably OK to run without the washer. But if your like me I'd want it there because it's supposed to be. Hope the calls get you some help and happy tumbling.
