Post by jamesp on Feb 19, 2015 13:45:38 GMT -5
Looking at using the Viking 'tub type vibratory tumbler' . Making a new lid that has dividers so that 3 rough shaped spheres can be tumbled side by side in hard media. The dividers are commonly used in tub type vibes that can be 3- 20 feet long in the industrial sector. Dividers made of rubber or plastic, connected to a custom made cover, inserted from above to segregate the spheres. Dimensions of opening is 11.5 inches X 3.5 inches. But the urethane liner could be opened a bit for a short distance at the mouth to allow a 4 inch sphere to pass. So two 4 inch spheres and one 3 inch sphere could run at the same time in the Viking 14 pound hopper, dividers to keep them from hitting each other. Presently running a full hopper of 5 mm garnets. They do well for laying a polish down on smaller tumbles when grit is added with them. Today a 3 inch 'sphere' was dropped in with them as a test. It was tumbled smooth in the rotary using SiC 30/60. It also beat up the other tumbles when in the rotary. It is rolling just fine in the vibe with the garnet media with SiC 220 grit. Which breaks down in one to three days normally imparting a nice polish. The urethane liner will do fine with SiC 80 grit too, but not coarser. Photo of hopper: Cover is basically a flat plate and easy to reproduce. Good seal not necessary.
Post by jakesrocks on Feb 19, 2015 15:22:53 GMT -5
Only problem I can see is if your spheres have varying degrees of hardness in the material. Soft spots may tend to undercut. Less chance of that happening if you work through various stages of grit in conventional sphere cups.
Post by jamesp on Feb 19, 2015 19:03:36 GMT -5
Only problem I can see is if your spheres have varying degrees of hardness in the material. Soft spots may tend to undercut. Less chance of that happening if you work through various stages of grit in conventional sphere cups. Absolutely Don. Vibe likes to undercut. to a fault. A draw back of tumbling process. It looks as if a long piece could be rolled in that machine, like a limb cast say 3 inches diameter and 11 inches long.
jerrys
Member since February 2014
Post by jerrys on Feb 20, 2015 13:20:49 GMT -5
When petrified wood twigs or limbs are tumble polished, their value is destroyed.
Post by jamesp on Feb 20, 2015 13:34:03 GMT -5
When petrified wood twigs or limbs are tumble polished, their value is destroyed. Perhaps to some. It increases the value to me. A similar subject arrises with many stones on this forum. It is a rock tumbling forum. That involves cutting and grinding of stones.
SirRoxalot
Member since October 2003
Post by SirRoxalot on Apr 4, 2015 14:30:24 GMT -5
Are you using a sphere machine at all?
Is vibe tumbling a viable way to polish a sphere???
Cool beans.
