Post by Tommy on Mar 18, 2015 16:55:08 GMT -5
I came across this unit in a pile of lapidary "junk" someone gave me. 10 points to the first person who can identify it - it might not even be lapidary related, I have absolutely no idea. It seems to be some sort of lathe ... the two aluminum discs adjust open and closed but only for a small amount - maybe as wide as ring?
spiritstone
Member since August 2014
Post by spiritstone on Mar 18, 2015 17:12:11 GMT -5
No clue. Just going to guess at some kind of press?
Post by jakesrocks on Mar 18, 2015 18:17:27 GMT -5
With the gear head motor, it'll run at low RPM's. I'm guessing some sort of tool grinder or sharpener. I'd clean it up & plug it in to see what sort of action you get out of it.
Post by Tommy on Mar 18, 2015 18:50:33 GMT -5
With the gear head motor, it'll run at low RPM's. I'm guessing some sort of tool grinder or sharpener. I'd clean it up & plug it in to see what sort of action you get out of it. Yes it runs ... slowly like you said. I still have no idea.
Post by Tommy on Mar 18, 2015 18:51:15 GMT -5
No clue. Just going to guess at some kind of press? It's very small for a press...probably about 15" in overall length.
Post by orrum on Mar 18, 2015 19:00:00 GMT -5
Cab preformer!
Post by Tommy on Mar 18, 2015 19:10:43 GMT -5
I can't tell if the one-legged cowboy is pulling my leg again haha.
Post by orrum on Mar 18, 2015 22:37:07 GMT -5
Well now Tommy it could be a goose plucker with a few modifications too!!! LOL
Post by Deleted on Mar 19, 2015 0:12:31 GMT -5
Looks to me like it spins some kind of various plates with a cutting edge. Grooving tool maybe.
How fast is slow? Jim
Post by snowmom on Mar 19, 2015 5:08:26 GMT -5
Looks to me like it spins some kind of various plates with a cutting edge. Grooving tool maybe. How fast is slow? Jim for making serrations in a knife blade? the clamp shown in one photo seems to be designed to hold thin flat plate of some sort. Maybe for working something with sheets of stained glass? Oh I hope you figure it out, I hate unsolved mysteries!
Post by jamesp on Mar 19, 2015 6:17:30 GMT -5
A polytronic grinipulator. Just kidding. Looks like some kind of tool sharpener as mentioned. Sure is well made. mohs ?? Does the clamping screw assembly slide left to right on the spinning shaft ? if so, it about has to be a sharpener of some sort. slow rotation to avoid heat buildup ? scissors sharpener ?
Post by jakesrocks on Mar 19, 2015 8:54:48 GMT -5
Can you make a quick flic of it running ? May be able to figure it out if we can see it running.
Post by gingerkid on Mar 19, 2015 9:17:09 GMT -5
Tommy, I showed your photos to Rick this morning. He said he thought it may be a key making machine and that it looks as if it is missing some parts. ??
Post by mohs on Mar 19, 2015 9:18:48 GMT -5
I'm surprised I never seen anything like it in sharpening or locksmiths that resemble that machine. It sure does look like something from those crafts. Maybe for the leather trade? Some sort of slitter?
Post by Fossilman on Mar 19, 2015 9:20:59 GMT -5
Gotta love old school machinery..........
Post by Tommy on Mar 19, 2015 10:03:45 GMT -5
Can you make a quick flic of it running ? May be able to figure it out if we can see it running. I will! I'll try to do it tonight.
Post by jamesp on Mar 19, 2015 10:08:13 GMT -5
I'm surprised I never seen anything like it in sharpening or locksmiths that resemble that machine. It sure does look like something from those crafts. Maybe for the leather trade? Some sort of slitter? If Ed has not seen it then it probably is not a sharpening device. Ed is sharp, mostly.
Post by jakesrocks on Mar 19, 2015 10:30:14 GMT -5
I just googled vintage key cutting machines. Lots of pics, but no match. It does look like it could be some sort of key machine with a few parts missing. The thing that throws me off is the gear reduction motor. Key cutters turn at high speed. I love mysteries like this. We gotta figure this one out.
If nothing else, there should be parts in it that can be adapted to lapidary use.
Post by fantastic5 on Mar 19, 2015 11:56:50 GMT -5
Watchmakers Lathe? Google searches turned up things that looked like this: and Granted it looks like yours turns from both sides, but maybe this will get people headed in the right direction?
Post by mohs on Mar 19, 2015 16:41:52 GMT -5
I'm surprised I never seen anything like it in sharpening or locksmiths that resemble that machine. It sure does look like something from those crafts. Maybe for the leather trade? Some sort of slitter? If Ed has not seen it then it probably is not a sharpening device. Ed is sharp, mostly. I'm glad to know I'm not dull m0stly
