Post by Fossilman on Apr 9, 2015 12:49:26 GMT -5
To us beginners on tumbling-check your equipment often,if not everyday...I checked the tumblers out yesterday..... Heard a weird noise coming from my 45C Lortone,but shunned it off.The 3A Lortone was fine.... Today I checked out the tumblers and found out what the noise was on the bigger tumbler,it was a belt ready to break!!! The smaller tumbler did a puke on me!!! LOL Cleaned up the mess,and the 3A is rolling again-Thumbs up... The 45C is down and the belt has been ordered.....Ordered one for the 3A too.... The 3A............ Cleaned up and ready to go again.... After I get the parts for the 45C,it will be stripped and cleaned,before I start it up again..It needs it! Thumbs up
Post by snowmom on Apr 9, 2015 13:06:10 GMT -5
always something! Good you're rolling again. Keep us posted!
Post by Fossilman on Apr 9, 2015 13:55:58 GMT -5
Just received an email,my belts are on the way already-Fast service!!!
Post by jamesp on Apr 9, 2015 14:11:07 GMT -5
One of the gambles of tumbling Michael. Looks like you caught it before it ran dryer and bruised your babies up. I was going to say take note of that sound but I believe it sunk in your brain well. Hope it was a slow leak,; if the cap pops off or worse a fast leak it will sure bust your rocks up, almost trash them.
One of my barrels ran up against the end and rubbed a big hole in the cap and ran all night dry, but full of rocks. It chipped and frosted them terribly; I basically canned them.
Post by johnjsgems on Apr 9, 2015 14:40:08 GMT -5
You should check/clean the roller bearings too. Easier to clean and relube than it is to replace shafts and bushings.
Post by braders on Apr 9, 2015 15:54:33 GMT -5
Ha ha been there buddy !! Mine like to do it in the night or while at work . Lids give on my thumblers I have almost learned to not say to self when they are worn "oh hell I can get another week or two outta it " NO !!!
Post by Fossilman on Apr 9, 2015 17:44:52 GMT -5
You should check/clean the roller bearings too. Easier to clean and relube than it is to replace shafts and bushings. I usually field strip most of my equipment,than make sure nothing is worn out or needs replaced soon.............
tkvancil
Member since September 2011
Post by tkvancil on Apr 10, 2015 9:30:24 GMT -5
Two questions .... What kind of material was in the 3A ? .... And I see a can of flex seal, that stuff work ?
Post by Fossilman on Apr 10, 2015 9:38:42 GMT -5
Two questions .... What kind of material was in the 3A ? .... And I see a can of flex seal, that stuff work ? Material was Montana agate and jaspers........... The flex seal is like a repair kit for a simple fix-till you get the repair job done the right way.... It's a silicone base spray that works for awhile,than you start over-LOL.....
tkvancil
Post by tkvancil on Apr 10, 2015 11:03:29 GMT -5
That's a head scratcher as to agate and jasper having a blowout fossilman. Usually that stuff doesn't gas off. Thanks for the info on flex seal. Commercials looked too good to be true.
Post by Fossilman on Apr 11, 2015 17:38:56 GMT -5
That's a head scratcher as to agate and jasper having a blowout fossilman. Usually that stuff doesn't gas off. Thanks for the info on flex seal. Commercials looked too good to be true. I did have a homemade slurry going too-LOL......................
Post by Fossilman on Apr 11, 2015 17:41:22 GMT -5
Fast service,got the belt already..............Ordered one for the smaller tumbler too (to have on hand)...
Post by captbob on Apr 11, 2015 19:50:21 GMT -5
That's a head scratcher as to agate and jasper having a blowout fossilman. Usually that stuff doesn't gas off. I did have a homemade slurry going too-LOL...................... Which consisted of...??
Post by Fossilman on Apr 11, 2015 20:14:15 GMT -5
I did have a homemade slurry going too-LOL...................... Which consisted of...?? It was a bought grit,plus a sugar base,that I added to thicken the slurry.............
Henry
Post by Henry on Apr 11, 2015 20:57:39 GMT -5
Yikes!!
Post by Fossilman on Apr 13, 2015 11:31:07 GMT -5
Just put the larger tumbler back on(had a bad belt) and the motor doesn't do anything-LOL...Think of replacing it with a new motor ($40.00)....Had more problems with it than I though...But should be like new when I get done with it..Thumbs up
Post by gingerkid on Apr 13, 2015 11:41:25 GMT -5
I'm sorry to hear that your motor is bad on your large tumbler, Fossilman. Sure hope you get the motor replaced asap. Did you place oil in the oil ports on your motor before you started tumbling?
Post by Fossilman on Apr 13, 2015 18:02:10 GMT -5
It was already to go-a buddy bought a bigger one and gave me this one-he was working it a week before he changed out... I'm still going to take it apart and look at it-I'm pretty good at making things work...
