Post by mohs on Apr 19, 2015 22:25:08 GMT -5
Post by Fossilman on Apr 19, 2015 22:40:00 GMT -5
Totally cool Ed!!!!!!!!!!!!!!!!!!!!
grizman
Member since July 2011
Post by grizman on Apr 19, 2015 22:45:16 GMT -5
Now that is worthy piece of art that you have created to commemorate the wonderful church. Where will the piece go now?
Post by orrum on Apr 20, 2015 6:37:29 GMT -5
Ed that's a great couple!## The colors are so vibrant!
rockroller
Be excellent to each other.
Member since October 2013
Post by rockroller on Apr 20, 2015 9:23:59 GMT -5
Holy Smokes Ed!!! That is beautimous!!! If that were for sale I would make it 'Sold!'
~Roland
Post by gingerkid on Apr 20, 2015 10:24:35 GMT -5
Wow, edmost™, your sacred heart is beautiful and rockin'!! Both sides of it are stunning. I think both sides of it deserve to be seen and admired, and wondered if there's anywhere that you could place a watch fob-type bail on it so it would flip sides while worn?
Post by drocknut on Apr 20, 2015 10:40:29 GMT -5
Wow Ed that is definitely rockin. A fitting tribute for sure.
Post by rockjunquie on Apr 20, 2015 10:40:39 GMT -5
Wow, Ed!!!! That is totally worth all grinding! It is beautiful! I love that rock and it is so perfect for a heart.
Post by mohs on Apr 20, 2015 17:58:32 GMT -5
Thanks Tela ! I happened to be messaging Tela Sunday & mentioned that the heart took me 5 hours to grind. I was little embarrassed by that. Is that excessive? What I'm trying to show here is the profile. This heart is probably only relieved the minimum amount to effect a shallow dome. Just enough to get all the flats out. Especially difficult areas are the heart of the heart and up around the homps. just like dead cent on the top of cab. (Although I have found that if I prep grind the stone properly, before epoxy them together, I really save lots of finesse grinding around the homps) Nonetheless it really turns into lots of grinding especially when doing both sides. I want to learn how to grind that profile to a razor edge. That will really bend a heart and give it a high dome. But as you can see... I still be out grinding on this heart if attempted it with this one. I need a magic roughing wheel Thanks Everyone !! I will reply in kind....
Post by pghram on Apr 20, 2015 18:48:50 GMT -5
Love the red color, yes, perfect for the heart.
Rich
Post by mohs on Apr 24, 2015 14:41:31 GMT -5
A pic of the Sacred Heart Church Took it on one of my breaks I work in that white building to the right As mentioned the area was once full of homes and the airport bought out the barrio So I hound the field for artefact's and whatever ...
Post by mohs on Apr 24, 2015 14:43:42 GMT -5
This is the plaque commemorating the church What I want to do is photoshop the heart in front of the plaque The plaque is about 30 yards away Had to take the picture through a chain link fence How would I go about photchopping the heart in? Should I go take another picture with the heart hanging in front of the plague 30 yards away. Then try to do some photo chop manipulation ? Any idea? Thanks Ed
Post by rockjunquie on Apr 24, 2015 14:52:11 GMT -5
Try going in on a Sunday and get a more clear shot. PS should be pretty easy to with or without using layers. But, yeah, if you could get in with it being open, then you could get a picture of the heart hanging in front of the sign BUT, depending on your camera, you may have a focus problem with the sign being out of focus. Hmm.... get a good sign shot, seperate heart shots (taken at the same time using the same days light) and then ask for PS volunteers. I'm not as good as a lot of people but, if no one else will help, I will. edit, I should add that it would be best to do the heart picture against a white or light solid background to make it easier to cut out.
