Post by orrum on Apr 23, 2015 7:02:33 GMT -5
So I notice that Covington lists Pumice powder or grit, apparently it comes in several grit sizes and so it must be for tumbling rocks? What is it and can I use it in place of Silicon carbide?
Post by orrum on Apr 23, 2015 7:03:44 GMT -5
Shoot hit the wrong button! Anyhow has anyone used it? It comes in several sizes.
Post by jamesp on Apr 23, 2015 7:27:31 GMT -5
Bill, I believe fly ash from man made process is a similar abrasive. I think it has up to 30% aluminum oxide. Lots of good cheap abrasives, the cost is in crushing and screening it. I doubt it will coarse grind, SiC hard to beat. But will do the light work like putting 500/1000/polish finish down.
tkvancil
Member since September 2011
Post by tkvancil on Apr 23, 2015 10:37:19 GMT -5
Did a quick google search. Like James said, looks like it is a polisher and not a grinder.
Post by captbob on Apr 23, 2015 10:41:44 GMT -5
Without looking it up, I wonder if it's meant to be used as a dry abrasive - like for polishing/cleaning brass shell casings?
4936musse
Member since October 2015
Post by 4936musse on Dec 29, 2016 2:19:42 GMT -5
I think you have to mix the pumice powder with water to pollish.
