Post by glennz01 on May 7, 2015 22:00:42 GMT -5
Well i'm making this for someone and its a little challenging with getting the inside corners rounded out perfect. any suggestions?
unclesoska
Member since February 2011
Post by unclesoska on May 7, 2015 22:56:11 GMT -5
Looks good to me...
Post by stephan on May 8, 2015 0:11:16 GMT -5
It does look nice. If you are using a cabbing machine, there are limits. I have had some luck with the soft wheels.
I think a Dremel-type tool or a flex-shaft is what may be used commercially.
Good luck.
Post by bobby1 on May 8, 2015 0:21:02 GMT -5
I work the "V" off the edge of my grinding and sanding wheels. You can get the shape a bit deeper than shown up to a 90 degree arc from one side of the "V" to the other. I use a small flex shaft grinding wheel and sanding wheels to get a depressed groove from the bottom of the "V" towards the center of the heart shape. It is a bit of a chore to get the tapered girdle sanded around the lobes on the "V" but with care and patience it can be done. Here is one that I made from Brazilian Agate. The "V" is as deep as I can get by using the edge of the wheels. This one id 3" tall. I got some of a groove down from the "V". Bob
Post by glennz01 on May 8, 2015 0:22:09 GMT -5
yeah i'm just using my cabbing machine. hopefully the soft wheels will do what I need.
Post by glennz01 on May 8, 2015 0:24:53 GMT -5
I work the "V" off the edge of my grinding and sanding wheels. You can get the shape a bit deeper than shown up to a 90 degree arc from one side of the "V" to the other. I use a small flex shaft grinding wheel and sanding wheels to get a depressed groove from the bottom of the "V" towards the center of the heart shape. It is a bit of a chore to get the tapered girdle sanded around the lobes on the "V" but with care and patience it can be done. Here is one that I made from Brazilian Agate. The "V" is as deep as I can get by using the edge of the wheels. This one id 3" tall. I got some of a groove down from the "V". Bob Thanks for the pic bob. I'm guessing mine will look similar to yours when i'm done.
Post by orrum on May 8, 2015 4:09:34 GMT -5
They r both great works!
Post by gingerkid on May 8, 2015 18:29:22 GMT -5
Beautiful hearts, glennz01 and bobby1! What material is the heart, Glenn? Beautiful stuff! Is it for your mom for Mothers Day? mohs™ Ed kindly sent me a green wheel (SC) a couple of years ago to use for difficult cuts, and you can use your dremel tool and wheels as others have advised.
Post by pghram on May 8, 2015 18:42:35 GMT -5
Nice hearts.
Rich
Post by glennz01 on May 9, 2015 11:39:39 GMT -5
I started playing with the outside edges of the wheels and that may be a kea for me. I don't have the polishing dremel bits.
The stone is mexican sagenite palm wood.
Thanks for the tips.
whenever I finish it i'll post a pic.
Post by glennz01 on May 14, 2015 0:32:12 GMT -5
Just finished. I only used my caber an not dremel.. time consuming but it can be done. My picture does a bad job at showing the polish Also the large crack looking thing is not a crack... it used to have been but it is all minerals now... the only crack is in the bottom if you look hard. Never noticed the color difference until now (on the fossilized crack since I don't know what to call it)
Post by gingerkid on May 14, 2015 12:13:30 GMT -5
Your heart cab is beautiful, glennz01! Nice work, and amazed that you were able to cab the difficult area on your wheels.
Post by Fossilman on May 14, 2015 12:18:06 GMT -5
Awesome heart! Thumbs up
riverrock
Member since April 2010
Post by riverrock on May 14, 2015 18:46:18 GMT -5
Well done. The more you make the better you get.
Post by glennz01 on May 14, 2015 20:57:06 GMT -5
The best way I learn is by challenging myself
Post by snowmom on May 15, 2015 6:01:33 GMT -5
those are good ones, I collect hearts and would be proud to have either (and both) of those in my collection. Very nice!
Post by glennz01 on May 15, 2015 10:42:59 GMT -5
those are good ones, I collect hearts and would be proud to have either (and both) of those in my collection. Very nice! i'll probably be making a few more soon... one for sure as I need to make one for my co-worker... will make it out of a bloodstone like material
