Post by captbob on Jul 16, 2015 16:39:58 GMT -5
Howdy...
Got a rock in the mail today and it has what looks like glue dripped down one side. Don't know for sure that it's glue, but that's my best guess.
Any tried and true glue removal methods? Don't want to go too extreme and damage the rock. If that's even possible.
Figure I'll start with very hot water and go from there. Just thought it was worth asking if anyone had been there done that.
Thanks!
Post by captbob on Jul 16, 2015 17:10:29 GMT -5
Alrighty... boiling water did not work. Let it sit in the boiling water and used a stiff bristle scrub brush.
No joy.
next?
Post by johnjsgems on Jul 16, 2015 17:48:29 GMT -5
Lacquer thinner is amazing stuff for many things.
Post by captbob on Jul 16, 2015 17:53:18 GMT -5
Just tried acetone - didn't work either.
Time to go dig around in the garage and see what else I have.
Found mineral spirits - off to Google...
Post by jakesrocks on Jul 16, 2015 18:25:22 GMT -5
Explosives ? C-4 removes all sorts of stuff.
If it's epoxy or an epoxy type glue, soaking in acetone may take several hours. Try heating a sewing needle & sticking it in the adhesive. If epoxy based, you should be able to smell it.
Post by Drummond Island Rocks on Jul 16, 2015 19:25:23 GMT -5
When I attach my cabs to my wine stoppers I use 2 part epoxy. I had one get glued crooked and had to soak it in acetone for over a week to break the bond. Trick was not letting the acetone evaporate for a week.
CHuck
grizman
Member since July 2011
Post by grizman on Jul 16, 2015 19:29:31 GMT -5
Maybe direct heat will burn it off? I have no idea what type of rock you have, but a butane torch may be able to burn it off if it is something like a resin or lacquer? Obviously, I'd be careful if the rock is delicate or you think it could crack...
No real knowledge here, just a "maybe" type idea.
Post by victor1941 on Jul 16, 2015 20:48:46 GMT -5
If solvents don't remove the glue you might grind or sand it if the rock is not damaged.
Post by orrum on Jul 16, 2015 20:53:40 GMT -5
Be the glue, love the glue, feel the glue, see the glue, know the glue..... Be happy and keep the glue?
Post by Fossilman on Jul 16, 2015 22:20:19 GMT -5
I usually sand it away with sandpaper-by hand....
Post by Pat on Jul 16, 2015 22:24:04 GMT -5
Don't have a clue. White vinegar removes some things.
Post by captbob on Jul 16, 2015 22:57:44 GMT -5
Thanks to all for the suggestions. Haven't got it yet. It's on rough stone, so no sanding it off. Will try other approaches tomorrow when it's light out.
Post by jakesrocks on Jul 16, 2015 22:57:59 GMT -5
Very ccareful work with optivisors & dental picks will probably do the job if your rock isn't too delicate. Dental picks & surgical blades are your friends for all kinds of delicate work. Also the kind of files used for wax carving. They don't clog up like regular needle files will.
agatemaggot
Member since August 2006
Post by agatemaggot on Jul 17, 2015 7:18:54 GMT -5
You might try soaking in WD-40, place in small plastic bag and spray liberally, let stand overnight sealed so it does not evaporate. That stuff has some scary solvents in it.
Harley
Post by Fossilman on Jul 17, 2015 10:14:46 GMT -5
You might try soaking in WD-40, place in small plastic bag and spray liberally, let stand overnight sealed so it does not evaporate. That stuff has some scary solvents in it. Harley I use WD-40 on everything,works like a charm!!
Post by captbob on Jul 17, 2015 11:47:10 GMT -5
May try WD 40 next once the rain quits. Thanks guys! Happy Birthday agatemaggot
Post by broseph82 on Jul 19, 2015 13:09:22 GMT -5
When I attach my cabs to my wine stoppers I use 2 part epoxy. I had one get glued crooked and had to soak it in acetone for over a week to break the bond. Trick was not letting the acetone evaporate for a week. CHuck How would putting it in the fridge while in acetone? Would the acetone still evaporate??
Post by captbob on Jul 19, 2015 13:24:19 GMT -5
How would putting it in the fridge while in acetone? Would the acetone still evaporate?? You might get away with that at your house, but having all the food in the fridge absorb the acetone smell isn't something I want to consider the consequences of around here. Been a busy weekend and haven't gotten back to this yet. Will see what I can do this coming week.
Post by broseph82 on Jul 19, 2015 15:25:58 GMT -5
captbob I have an extra fridge that doesn't house food only bottled/Canned drinks
Post by snowmom on Jul 29, 2015 7:10:08 GMT -5
I am wondering about 'the rest of the story' captbob Were you able to remove the glue?
