castaway
Member since June 2015
Post by castaway on Aug 9, 2015 8:56:43 GMT -5
Would you use SAE 10 weight non det. in your 7 in saw? Asking because I have some on hand.
Post by broseph82 on Aug 9, 2015 10:28:23 GMT -5
Would you use SAE 10 weight non det. in your 7 in saw? Asking because I have some on hand. If you wanna smell like a mechanic. Wear something over your nose and mouth so you don't breathe in the oil fumes/mist.
Post by jakesrocks on Aug 9, 2015 10:51:28 GMT -5
Why waste good oil when saws 10" and under will do just fine with plain old tap water ? Just drain the saw & spray the blade with any good penetrating oil after use to prevent the blade rusting.
castaway
Post by castaway on Aug 9, 2015 18:25:34 GMT -5
got mineral oil to use.
rockroller
Be excellent to each other.
Member since October 2013
Post by rockroller on Aug 9, 2015 19:29:06 GMT -5
You gotta wait for the stuff to ship but I definitely recommend a water based product with rust inhibitor. A bah-jillion times better than messing with the oil mess!
~Roland
Post by Rockoonz on Aug 30, 2015 22:20:08 GMT -5
Yep, either the smokeys ez cut that John sells or the diamond pacific additive with water.
Post by orrum on Aug 31, 2015 7:59:10 GMT -5
I use Smokey from John! Love it!
jerrys
Member since February 2014
Post by jerrys on Aug 31, 2015 14:20:50 GMT -5
NO to SAE 10 weight non det oil.
barclay
Lowly Padawan of rocks
Post by barclay on Sept 10, 2015 17:20:36 GMT -5
Definately stay away from the SAE oil, it is not made to be inhaled or soaked into your skin. Mineral oil or water are much safer.
Post by Fossilman on Sept 11, 2015 9:50:15 GMT -5
Mineral oil!!
castaway
Post by castaway on Sept 11, 2015 20:05:52 GMT -5
I used mineral oil, and it worked well. I cut about 100 pieces. I used water and soap next. (the blade a 301 was getting to show ware). Then the cutting edge came off. Got lots to work on this winter.( if I am not on the beach.
