Post by Jugglerguy on Aug 30, 2015 15:07:39 GMT -5
I was asked the other day to show how I cut Michigan shapes from Petoskey on a trim saw, so I made a video today. Unfortunately my hand blocked much more of the action that I thought it would, but you can sort of see how I do it. Basically I use the edge of the blade as a grinder. I try to make the last pass along an edge by dragging the rock backwards along the blade. You'll notice that I built a ramp for my saw. That's so the blade and the ramp make a 90 degree angle. Without the ramp the blade is wider at the table and gets narrower the higher you go. So the blade will cut the bottom of the slab deeper than the top. This isn't a problem when cutting convex shapes like oval cabs, but when cutting concave shapes, like the bays around Michigan, it doesn't work so well. The same thing happens on a table saw if you are cutting an inside corner. Petoskey stone is very soft, so the process goes quickly. When I do shamrocks out of epidote, I have to cut a lot slower, but the process is the same. The rock I do in the video has the Michigan outline backwards because it was easier to draw it on the back of the rock, but I thought the other side looked better. Don't worry, it looks like Michigan when it's flipped over. For those of you living in states like Wyoming or Colorado, this whole process is much easier. When I'm finished on the saw, I polish them on a flat lap. Sometimes I leave them flat and other times I dome them.
Post by mohs on Aug 30, 2015 17:03:27 GMT -5
that be some fine saw carving dude !
I never tried to finesse on my 10" saw usually I use 7" workforce blade for that trying to get closer to the line the blade a bit more stable I see that flexing in the 10"
good job!
cobbledstones
Member since January 2014
Post by cobbledstones on Aug 30, 2015 21:41:50 GMT -5
nice work, precision and finesse. thanks for the tute
rattlehead
MI Rocks
Member since December 2010
Post by rattlehead on Sept 13, 2015 19:16:45 GMT -5
Those look great!
Post by Jugglerguy on Sept 13, 2015 19:20:42 GMT -5
Thanks!
Post by frane on Oct 24, 2015 7:05:19 GMT -5
I think I am going to have to make a ramp for my saw. This is a great tutorial!
Thanks,
FranE
Post by orrum on Oct 24, 2015 7:18:21 GMT -5
Ahh great video Rob!
Post by kk on Oct 24, 2015 9:39:58 GMT -5
At what speed are you running the blade?
Post by Jugglerguy on Oct 24, 2015 11:11:42 GMT -5
1437 rpm, I think. 1725 rpm motor with a 2.5 inch pulley on the motor and a 3 inch pulley on the saw. I have no idea if that's a good speed or not, it's just how my saw is set up.
Post by jamesp on Oct 25, 2015 5:23:32 GMT -5
Nice blade speed. Darn tile saws are too fast. Too much chipping.
Think about doing Alaska and it's Aleutian Islands.
Fine work Rob.
TByrd
Have you performed your random act of kindness?
Post by TByrd on Oct 27, 2015 9:04:26 GMT -5
I really like the ramp, what gave you the idea to make that? I am going to make one of those for my 10" and maybe for my 6".
Nice tutorial. I dont think Idaho would be too bad to carve out like that.
Tammy
Post by Jugglerguy on Oct 27, 2015 11:41:28 GMT -5
You have to use Idaho's state stone. I'm so jealous of the rectangular states!
I think Chuck (Drummond Island Rocks) gave me the ramp idea. As soon as you cut one without a ramp and then flip it over, you'd get the ramp idea yourself.
