castaway
Member since June 2015
Post by castaway on Sept 2, 2015 11:41:14 GMT -5
I have a slant lap, and want to try using a wood disk to polish with. What can I use to make the diamond powder stick to the wood?
Post by orrum on Sept 2, 2015 13:15:38 GMT -5
The diamonds I'm bed into the wood. Put them on and slowly turn it so you don't sling it off and go over it with a smooth agate cab. It will push the diamond in. Once it's I'm bedded it won't sling off. Spray some silicon on the wood first to help make the diamond stick until I'm bedded plus your cab will ride smoother.
Post by roy on Sept 2, 2015 16:51:31 GMT -5
better ground your self those things build up a nasty charge ! i still have twitch
bsky4463
Member since September 2013
Post by bsky4463 on Sept 2, 2015 18:42:40 GMT -5
better ground your self those things build up a nasty charge ! i still have twitch ahhh ...that explains alot! (not talking about the diamonds or the lap ) Cheers
Post by orrum on Sept 2, 2015 19:14:14 GMT -5
Lol Roy you ain't right!!!
Post by roy on Sept 3, 2015 10:10:34 GMT -5
better ground your self those things build up a nasty charge ! i still have twitch ahhh ...that explains alot! (not talking about the diamonds or the lap ) Cheers lol it was like a lightning bolt
Post by orrum on Sept 3, 2015 10:56:12 GMT -5
Did it inspire you Roy? LOL Wish I could seen that!
gemfeller
Member since June 2011
Post by gemfeller on Sept 3, 2015 14:12:01 GMT -5
Roy, they call it electro-rock therapy.
