Post by Drummond Island Rocks on Sept 15, 2015 19:40:17 GMT -5
A friend of the family asked if I had a spare tumbler I could loan them to see if they could get their 8 yr old to try tumbling the rocks they found this summer walking the beaches. I have plenty of 3 pound Lortone barrels laying around but they were originally for my home built tumbler so I do not have frames for them. I was wondering if anyone has a decent 3A single or 3B double frame laying around without barrel(s) that they would be wiling to part with. My other option is to have them buy a harbor freight cheapo just to get their feet wet but if I can get a frame cheap enough I will just give it to them with a barrel and grit to see if I can get another youngster hooked. Not looking for a handout just something affordable so I can donate it. If nobody has anything I can hit up ebay.
Thanks, Chuck
Steve
Member since June 2005
Post by Steve on Sept 15, 2015 23:07:19 GMT -5
Don't start them with Harbor Freight. That will just discourage them. Can't you hammer together a quick homebuilt?
Post by captbob on Sept 15, 2015 23:27:49 GMT -5
yeah Chuck... and when you finish with theirs, can you whip me up one that can run four Thumler's 15 lb barrels along with a 40 lb barrel on the bottom level? I've been meaning to hammer one together, but you could probably have it done by Friday. That would save my having to figure out all that pulley math stuff.
Thanks!
Post by MrP on Sept 16, 2015 4:34:31 GMT -5
yeah Chuck... and when you finish with theirs, can you whip me up one that can run four Thumler's 15 lb barrels along with a 40 lb barrel on the bottom level? I've been meaning to hammer one together, but you could probably have it done by Friday. That would save my having to figure out all that pulley math stuff. Thanks! captbob Like This......................................MrP
Post by Drummond Island Rocks on Sept 16, 2015 6:44:55 GMT -5
yeah Chuck... and when you finish with theirs, can you whip me up one that can run four Thumler's 15 lb barrels along with a 40 lb barrel on the bottom level? I've been meaning to hammer one together, but you could probably have it done by Friday. That would save my having to figure out all that pulley math stuff. Thanks! I made an excel document back when I built mine so all you do is type in your pulley sizes, shaft size, barrel size and motor RPMS and it spits out what RPM the barrel will spin. No more math to do. Chuck
Post by Drummond Island Rocks on Sept 16, 2015 7:01:26 GMT -5
The sad truth is that a very small percentage of kids that try tumbling rocks will actually stick with it for more then a couple batches. I can get a lortone 3A with barrel on ebay for $30 right now but I just thought I would check to see if someone had a frame in their junk pile first.
bsky4463
Member since September 2013
Post by bsky4463 on Sept 16, 2015 7:41:38 GMT -5
yeah Chuck... and when you finish with theirs, can you whip me up one that can run four Thumler's 15 lb barrels along with a 40 lb barrel on the bottom level? I've been meaning to hammer one together, but you could probably have it done by Friday. That would save my having to figure out all that pulley math stuff. Thanks! I made an excel document back when I built mine so all you do is type in your pulley sizes, shaft size, barrel size and motor RPMS and it spits out what RPM the barrel will spin. No more math to do. Chuck What a great reference doc. Nice work Chuck. Cheers
bsky4463
Post by bsky4463 on Sept 16, 2015 7:44:17 GMT -5
MrP great build, awesome tumble setup in a small foot print. I am curious as to what size HP motor you are running, I assume it's 1725. Cheers
Post by captbob on Sept 16, 2015 8:25:01 GMT -5
I believe ya'll may have missed the jesting in my post. yeah... kinda like that Mr. P Not sure that Chuck is a welder though, so I may have to settle for some of his fine cabinetry work. My wife likes mahogany... I like your no nonsense build there Mr. P is there a thread on it? If you stop back by and answer the motor question, I'd like to know how far apart the rollers are for the 40 lb barrel. I assume they are a wider spread than the smaller barrels. What is the RPM on your 40? Thank you. Is my tumbler ready yet Chuck?
Post by Drummond Island Rocks on Sept 16, 2015 8:40:35 GMT -5
I believe ya'll may have missed the jesting in my post. Is my tumbler ready yet Chuck? Nah, I got it. I was just egging you on a bit more. Chuck
Post by Sabre52 on Sept 16, 2015 17:07:30 GMT -5
Man, I've been cleaning my shop and just threw away three of those and a couple 12 pounder frames....Mel
Post by captbob on Sept 16, 2015 17:14:07 GMT -5
Threw something away? What's that even mean?
Post by Drummond Island Rocks on Sept 16, 2015 17:27:32 GMT -5
Man, I've been cleaning my shop and just threw away three of those and a couple 12 pounder frames....Mel I might be able to frankenstein one up. I have one of those lortone 3A motors still left that I bought from you awhile ago and I found an old 3A (gem sparkle) that I should be able to get going with that motor and a few other parts from the rockshed. Chuck
cardiobill
Member since March 2012
Post by cardiobill on Sept 16, 2015 18:20:22 GMT -5
Chuck I think I have exactly what your looking for A lortone 3a that isn't ancient Belts kept breaking and I took it apart but never really got it working well I'm sure you can fix it in 10 min Happy to send it your way
Bill
I may still have your address but PM me if you don't mind
Post by Drummond Island Rocks on Sept 16, 2015 19:13:59 GMT -5
Sounds like a winner Bill. I'll send you my address and work out details via PM.
Post by MrP on Sept 16, 2015 19:18:47 GMT -5
bsky4463 It is a 1725 RPM 1/4 HP. I had another setup with a similar motor on it and lost power in the house. The motor couldn't start and burned out so on this setup I put a relay in that keeps it running until power drops but has to be restarted with a manual switch.
I believe ya'll may have missed the jesting in my post. yeah... kinda like that Mr. P Not sure that Chuck is a welder though, so I may have to settle for some of his fine cabinetry work. My wife likes mahogany... I like your no nonsense build there Mr. P is there a thread on it? If you stop back by and answer the motor question, I'd like to know how far apart the rollers are for the 40 lb barrel. I assume they are a wider spread than the smaller barrels. What is the RPM on your 40? Thank you. Is my tumbler ready yet Chuck? captbob The large one is a 65lb barrel and turns at 25 RPM, the 15lb turn at 30 RPM and the 12lb turn at 32 RPM. I use Gorilla Duct tape on the metal edges of the 15lb barrels so I don't have metal to metal contact. I used 3/4" shafts because the price of 1" pillow block bearings was a lot more then 3/4"........................................MrP
1nickthegreek
Member since February 2014
Post by 1nickthegreek on Sept 16, 2015 20:03:23 GMT -5
Drummond Island Rocks I have a 33B frame sitting in my shop, newer one but I was having some issues with getting it to turn with loaded barrels so I threw it aside, hit me up and lets jabber about it a lil bit.
Post by Drummond Island Rocks on Sept 16, 2015 20:20:23 GMT -5
Drummond Island Rocks I have a 33B frame sitting in my shop, newer one but I was having some issues with getting it to turn with loaded barrels so I threw it aside, hit me up and lets jabber about it a lil bit. Thanks for the offer but I already have one coming from cardiobill. Maybe someone else following this will need yours? Chuck
