ckhopper
Member since August 2015
Post by ckhopper on Sept 21, 2015 12:43:47 GMT -5
Hey Folks! I'm gearing up to attempt to make jasper necklace carvings, simple ones to get started; Arrow heads, shark teeth (tooth). Having not done this before, I'll be using a Dremel tool and Dremel diamond bits, "work bench" will be a piece of sanded plywood and an old terry cloth towel.
Can I use water instead of the oil lube they recommend. Best methods or suggestions for final polish.
Any suggestions will greatly appreciated!
ckhopper
Don
He wants you too, Malachi.
Member since December 2009
Post by Don on Sept 21, 2015 15:02:37 GMT -5
ckhopper
Post by ckhopper on Sept 21, 2015 23:00:48 GMT -5
Thanks Don!
Post by kk on Sept 21, 2015 23:16:18 GMT -5
Thats a great tutorial. Thanks for sharing.
Jasper will be much easier to work with, but the procedure is pretty much the same. Looking forward to your exploits.
Post by paulshiroma on Sept 27, 2015 19:26:45 GMT -5
Welcome to the forum and good to meet you!
Post by Noosh9057 on Sept 27, 2015 20:38:32 GMT -5
Great information.
Roger
