micellular
Rock fever is curable with more rocks.
Member since September 2015
Post by micellular on Dec 15, 2015 0:03:59 GMT -5
Here's the reason I've been asking for preforms of softer stones! I've been working on this lace agate for the past two weeks, and while it's far from perfect (lopsided outline, major undercutting of the bands, and a shallow central dome), I'm ready to put it away for a while. Thank you radio for sending me the agate when I was just starting out! He sent it to me mostly-domed, which made the work so much easier. I don't think I would hand-sand an agate starting from completely un-domed slab. I took it from 80 to a 3000 grit paper. Must've used up at least $10 worth... Front Back. I like it just as much as the front - maybe I'll make a double-sided cab someday when I'm less sick of it. Side Polish
Post by paulshiroma on Dec 15, 2015 0:10:19 GMT -5
OUTSTANDING. That's a beautiful cab. Congratulations. And I'm really impressed that you did that with sandpaper. Later I'll find you cutting these by hand ...
Post by paulshiroma on Dec 15, 2015 0:12:55 GMT -5
BTW, I like the signature: Rock fever is curable with more rocks. Sort of like, "my hangover will go away after this next six-pack". Just one more toke ...
micellular
Post by micellular on Dec 15, 2015 0:14:26 GMT -5
Bahaha, I like your profile pic, paulshiroma. Certainly seems like it this cycle.
Post by kk on Dec 15, 2015 7:49:17 GMT -5
Thats how you get to know a stone. Takes a long time yes, but...... Looks great, well done.
I do all my stones from 400 to 2000 with paper. Then 14k and 50k Diamond-paste to finish them up (simply because the paste turns out cheaper than the paper as well as being super quick). But I do have 3,5 and 10000 paper in the ready should I not get the 30 minutes time on the machine.
Post by Drummond Island Rocks on Dec 15, 2015 8:00:07 GMT -5
Your perseverance was rewarded with a beautiful cab. Nice job.
Post by Deleted on Dec 15, 2015 8:27:47 GMT -5
Hhhooooollllyyyyy smokes batman!!!talk about an oncore!well done that is a tuff rock to be sanding by hand.youd be dangerous with a cab machine Dave
Post by Fossilman on Dec 15, 2015 11:58:18 GMT -5
Wow!! Really like the workmanship-great job!!!
adrian65
Member since February 2007
Post by adrian65 on Dec 15, 2015 12:19:15 GMT -5
What a tremendous work must have been, to bring that cab to that beautiful shape and shine only by hand! If you have the patience to do this by hand, I can only imagine how would your machined cabs look like. You should definitely make this step forward. It's a wander your fingers still look in such a good condition - fingerprints still visible. Or does someone else hold the cab in the pictures? Adrian
micellular
Post by micellular on Dec 15, 2015 12:44:32 GMT -5
adrian65, I can't take all the credit. Arlen sent me a preform that was 95% final shaped and domed. Since it was also dopped, that spared my hands quite a bit! But I should point out that's my NON-dominant hand pictured... Can't wait until January - that's when the club shop reopens and I can UNLEASH MYSELF UPON THE WHEELS!
Post by Drummond Island Rocks on Dec 15, 2015 13:37:17 GMT -5
I wish I would have known that it was easier for you to hand work with the dop sticks attached. I could have left them on the Kona cabs for you. If you do not have means to dop them with wax you could always try super glue and a 16 gauge framing nail.
Post by Peruano on Dec 15, 2015 15:08:07 GMT -5
Oh. . . and a wine cork on the roofing nail. We don't want blood on our stones. Nice job. Tom
Post by rockjunquie on Dec 15, 2015 15:15:19 GMT -5
You did an amazing job on that agate. I hope you are healing well. It's amazing what we'll go through for beauty isn't it?
micellular
Post by micellular on Dec 15, 2015 16:21:48 GMT -5
Chuck, that's what I usually do. Nail + superglue + no TSA!
Post by mohs on Dec 15, 2015 17:15:40 GMT -5
that lovely done stone, Michelle! here's method I've tried its rubber back sanding block and that curvature could help with the dome plus I always wonder if the inside of properly curved bowl with fine grit may be useful?
Post by Tommy on Dec 15, 2015 17:29:47 GMT -5
Very nice!
Post by radio on Dec 15, 2015 18:11:55 GMT -5
Here's the reason I've been asking for preforms of softer stones! I've been working on this lace agate for the past two weeks, and while it's far from perfect (lopsided outline, major undercutting of the bands, and a shallow central dome), I'm ready to put it away for a while. Thank you radio for sending me the agate when I was just starting out! He sent it to me mostly-domed, which made the work so much easier. I don't think I would hand-sand an agate starting from completely un-domed slab. I took it from 80 to a 3000 grit paper. Must've used up at least $10 worth... Front Back. I like it just as much as the front - maybe I'll make a double-sided cab someday when I'm less sick of it. Side Polish Doggone that came out nice!!! I let something like that get away from me?!?!? what was I thinking?!?!?! You still have my address? send that cab back to me for a surprise
micellular
Post by micellular on Dec 15, 2015 18:38:59 GMT -5
that lovely done stone, Michelle! here's method I've tried its rubber back sanding block and that curvature could help with the dome plus I always wonder if the inside of properly curved bowl with fine grit may be useful? Ed, I was initially using a rubber block and I think it helped with the doming, but not with the undercutting. Guess those tradeoffs are more apparent at very low speed. But I really like the idea of using a bowl! I'll try that next time, thank you!
Post by mohs on Dec 15, 2015 18:51:29 GMT -5
as far as your undercutting problem goes Michelle I think you'd have to pull out a magnifying glass to show me and by the time you did that you'd have lost me i like what I see with my own 2 eyes and that's a good camera picture smooth
Post by vegasjames on Dec 15, 2015 18:52:08 GMT -5
Nice job. May try sanding sponges in the future for at least the initial sanding. lasts longer than paper, easy to wash out and conforms to stone shape. I have used them to polish various rocks and meteorites.
