cobbledstones
Member since January 2014
Post by cobbledstones on Dec 19, 2015 14:23:29 GMT -5
Was at a conference and trade show last week for work and ran across this beast. Had to share, $1700 price tag
Post by Rockoonz on Dec 19, 2015 17:12:06 GMT -5
Is $that$ all?
Post by Pat on Dec 19, 2015 22:27:45 GMT -5
Think I'll stick to my drill press. However, your beast would be helpful out in the wild. Wouldn't you still need a water source!
gemfeller
Member since June 2011
Post by gemfeller on Dec 20, 2015 0:49:46 GMT -5
Those core drills are made mainly for field geologists who need cores for a variety of reasons. I've seen films of them being used and if IIRC they didn't use water.
RocknCritter
Member since November 2008
Post by RocknCritter on Dec 20, 2015 9:41:24 GMT -5
Those core drills are made mainly for field geologists who need cores for a variety of reasons. I've seen films of them being used and if IIRC they didn't use water. You can see the connection for the water feed here.
gemfeller
Post by gemfeller on Dec 20, 2015 16:24:12 GMT -5
I said "if I recall correctly." Apparently I didn't. It must be exhausting to back-pack all that water into the wilderness.
SirRoxalot
Member since October 2003
Post by SirRoxalot on Jan 26, 2016 18:42:37 GMT -5
That's what grad students are for, lol. A simple backpack weed sprayer does the job, the drill pretty quick. And there's tons of good rock right next to roads to work on. Seems like a homemade version could be knocked up for a lot less than 1,700. With feather and wedges you'd have a sweet little boulder-buster!
Post by Deleted on Jan 29, 2016 14:00:37 GMT -5
That's what grad students are for, lol. A simple backpack weed sprayer does the job, the drill pretty quick. And there's tons of good rock right next to roads to work on. Seems like a homemade version could be knocked up for a lot less than 1,700. With feather and wedges you'd have a sweet little boulder-buster! And technically illegal. IIRC It requires a claim to use motorized equipment. Thanks gemfeller for the acronym!
minerken
Member since August 2013
Post by minerken on Jan 29, 2016 14:58:34 GMT -5
not that it couldn't be used by a geologist but I think those were designed for coring concrete. Back in the 80's when I was working for an exploration company we had a gas powered core drill called a Winkie they also had a rotary percussion drill you didn't have to use water with it. I think that unless the land is designated as no motorised equipment as long as just using it for surface samples you could probably get away with it and as long as you aren't using any water additives.
panamark
Member since September 2012
Post by panamark on Jan 29, 2016 17:07:39 GMT -5
would hate to be holding on to that when the core bit binds up in the rock.
Post by Fossilman on Jan 29, 2016 18:58:15 GMT -5
ZOWY!!! Would be a great toy though...
