Intheswamp
Member since September 2015
Post by Intheswamp on Jan 1, 2016 10:56:15 GMT -5
Well, the Money Pit Tumbler is coming up for a slight modification. What I thought was a good idea isn't working out. The clothes-dryer drum rollers that I used for a stand-off for the barrels are wearing out to quickly. Hitting the pvc end cap at an angle isn't helping them any (due to my non-professional hole drilling). So, I will be replacing them with "something" else...the "something" is yet to be determined. I'm considering metal rollers from a roll-up door, hard plastic wheels from a dolly, same hard plastic wheels from a desk chair, etc.,. To the point... I knew that the barrel favored that end of the tumbler, resting against that particular roller non-stop. What I didn't now was how strongly it was pressing in that direction. In an attempt to let the barrel push against the roller at the opposite end of the tumbler I slipped a piece of 2x (1.5") lumber under the "low end" that the barrel was pressing against. I figured this would be enough to send it to the other end of the rollers. Nope...didn't work. I added a piece of 1x (3/4") lumber to that...that didn't help. I have an 8" golf-cart wheel I use for a barrel stand...I sat it on my roll-off table and it would immediately start rolling to the lower side of the tumbler...but the barrel continued to climb uphill to the worn roller. Maybe there's something about the moving load inside and the direction of rotation that is creating a "screw effect" and giving the barrel some traction to move uphill. I'm puzzled. It doesn't matter which direction the barrel is pointing, either. I turned the barrel around so that the the ends were reversed but it still traveled uphill. Anybody know what causes this effect? I'm going to replace the dryer rollers with something else because it has to be done. But I'm curious as to why the barrel has this preferred direction of travel. I've read other "barrel creep" threads, but never found an answer to this mystery. Anybody?
jackangeline
Member since December 2015
Post by jackangeline on Jan 1, 2016 11:20:09 GMT -5
Intheswamp there are many reasons for barrel creep.
Out of level rollers Spread rollers (rollers not parallel) barrel tapered in some manner (PVC slightly different sizes) rotation of the earth phase of the moon you're not standing in the correct place on the correct foot
[/a] [/ul]
Post by jamesp on Jan 2, 2016 7:22:28 GMT -5
I tilt the whole tumbler slightly towards the end roller and run one end roller on one side only with no ill effects. And run shafts exactly parallel. Platform very flat, so shafts at same plane. Gravity reliable. You are obviously not having any luck with tilt. Tilt is about 3-5 degrees. Not this much: Hard to imagine it climbing with such a big slope. 3/4 inch shafts with 35 pounds ?? may be sagging. Try running barrel in center Ed. Like a hammock... You may have some bouncing judging form the marks on your barrel. If it is, each time it vibrates/bounces it may shift the barrel towards the center. Put the barrel in the center and turn machine off. Push down on barrel and see if shafts sags more. Remove barrel and check shaft sag after setting barrel back on shafts. Or try to make it bounce by tapping on it with your palm. You have some dynamic stuff going on related to shaft sag or a bent shaft.
Post by jamesp on Jan 2, 2016 7:55:20 GMT -5
Looking at this photo and trying to figure if the 3/4" shafts may be sagging with approximately 35 pound load in center. Looks like a 40 inch span. I would say yes, especially if the shafts are far enough apart to create a wedge from the barrel. The wedge is most likely happening, the deeper the barrel sits in the saddle the more the wedge force. The wedge force splitting the shafts will darn sure push the barrel away from the end. I have seen home made tumblers with a good bit of shaft sag and wedge out. And they require no end rollers. Because the barrel(s) seek the center hammock style. A clever way to avoid end rollers. I would let it run for a while barrel starting in center, tumbler sitting flat.
Intheswamp
Post by Intheswamp on Jan 2, 2016 13:56:41 GMT -5
jackangeline , I've looked/thought of most of what you wrote...I'll try the other foot when I check on the tumbler, I hadn't thought of that. I'll check the roller level, too. I was over a the shop for a short while and the shafts are within 1/16" of being parallel. I'm not sure about the level, though each shaft contacts the barrel in the same manner as it's partner, which makes me think it is level. The pipe portion of the barrel seems level with the shafts, though the coupling rides high in the center and the pvc cap rides high at the far end of it's straight side in the area just before it transitions to domed shape. jamesp , so the 3/4" *could* be flexing? I was thinking that length and size shaft would be bulletproof. The span between bearings is 38". I tried bouncing it today but it didn't bounce much and I don't see any movement outward as would be seen if the shafts were spreading. When running unloaded, the shafts run nice and true...no run-out, wobble, etc., that I can tell. I've placed the barrel at the opposite (motor) end and in the middle...it doesn't matter as it heads to the other end. I sat a 2-foot level up on the table and from one end of the level to the other is right at a 1" difference...the barrel consistently climbs the hill.
Intheswamp
Post by Intheswamp on Jan 2, 2016 14:45:05 GMT -5
Looking at this photo and trying to figure if the 3/4" shafts may be sagging with approximately 35 pound load in center. Looks like a 40 inch span. I would say yes, especially if the shafts are far enough apart to create a wedge from the barrel. The wedge is most likely happening, the deeper the barrel sits in the saddle the more the wedge force. The wedge force splitting the shafts will darn sure push the barrel away from the end. I have seen home made tumblers with a good bit of shaft sag and wedge out. And they require no end rollers. Because the barrel(s) seek the center hammock style. A clever way to avoid end rollers. I would let it run for a while barrel starting in center, tumbler sitting flat. Span is 38". In an earlier post (the build thread) you said the 3/4" shafts probably wouldn't sag under 150 pound load. From eyeballing it I think your earlier statement is closer to being correct and that they aren't sagging. The shafts are not spaced very far apart...5-5/8" center-to-center. They seem pretty solid at this span. I can see how the "wedge force" and gravity would encourage the barrel to travel to the wider space. I think the shaft spacing is ok though naturally I'm sure they're not perfectly parallel and thus contribute to a wedge force. What amazes me is the quickness of travel that the barrel exhibits....in less than two minutes the barrel will travel an inch. I first started out with the tumbler level and the barrel in the middle...it quickly traveled to one end and the subsequent wear showing on the rollers is what prompted me to start this thread. Interestingly, it doesn't matter which direction the barrel is pointed in...it travels consistently to the same (opposite from motor) side. For a moment I entertained the thought that the pvc fittings might be a bit "off" in matching dimensions and were maybe contributing to a wedge force, but if that was the case then the barrel would reverse travel direction when it was reversed on the tumbler. So, I'm scratching off the barrel contributing to the creep...there must be something inherit in the tumbler itself. The shaft spacing is pretty dog-gone close but I may widen the spacing excessively on the motor end and see if I can get the barrel to move in that direction. If that doesn't make a difference I'll have to say it must be sprites and fairies doing it. jackangeline, I got to thinking and the tumbler is aimed east and west...I wonder if I should turn it so it's situated north and south. Then the question of the direction of rotation of the barrel matching (or not matching) the rotation of the earth...lots to think about! captbob Barrel creep really doesn't matter in the functioning of the tumbler being as I'm going to have a roller stand-off in place regardless. Just something that really makes me wonder what's going on with a barrel climbing uphill.
Post by Drummond Island Rocks on Jan 2, 2016 14:45:14 GMT -5
My guess is the spread of the rollers changes from one end to the other. If your center to center is 5" at one end and 4.875 at the other the barrel will always travel to the 5" end even when the tumbler is tilted.
Intheswamp
Post by Intheswamp on Jan 2, 2016 14:51:45 GMT -5
Thanks for the feedback, Chuck. I've about convinced myself of this. I'll be intentionally widening the spacing on the non-frequented end of the roller pair soon to hopefully see for myself this happening. Apparently the spacing has to be more or less perfect from end-to-end of the roller pair for the barrel not to creep to one end, or at least to creep at a very slow speed. Stand-off rollers are a must!!
Post by Drummond Island Rocks on Jan 2, 2016 15:20:34 GMT -5
I set my distance with digital calipers and I can set a barrel dead center and it will run for hours without ever traveling toward either end.
Post by toiv0 on Jan 2, 2016 15:24:15 GMT -5
I have used rollers from rollerblades, very tough compared to dryer rollers. I agree the spacing of the shafts are probably the culprit. Not sure if it would go to the wider spacing depending on rotation of the drive. Aligning belts on conveyor with a tapered tail pulley is easy, but sometimes with straight or flat tail pulleys it is backward from common sense which makes no sense.
Post by toiv0 on Jan 2, 2016 15:25:35 GMT -5
Post by jamesp on Jan 2, 2016 18:10:14 GMT -5
As you are aware. If the side rollers go bad it can slow the barrel and the shafts can grind a notch in the barrels. I tilted mine a bit, it walked a bit when level, now the barrel barely touches the side roller.
It is a puzzle that your barrel is walking like it is. if shafts are parallel and the barrel walks when reversed it is an enigma.
I wondered if the reason for the walking when everything was level and lined up was the rocks impacting the internal shape of the different shaped barrel ends. Rounded cap end and wedged reducer end. 46 times a minute. Next time you do a clean out you could try the barrel with no rocks, or full of water so there will be weight w/no impact forces. Maybe the rocks are pounding it to one direction by striking the inside of the cap or bushing. I would be suspicious of the cap.
About 2 inches of tilt over it's 4 foot width kept mine from walking. That would be a double shaft, all 4 barrels with caps pointing west.
Intheswamp
Post by Intheswamp on Jan 2, 2016 20:01:35 GMT -5
Chuck, do your barrels eventually move to one end or the other? My measurements were definitely not NASA grade measurements...wooden ruler held against the side of one shaft and distance noted on opposite of other shaft. toiv0, roller-blade wheels would probably work great!!! If they can take the punishment like they do then being a stand-off wheel for a tumbler would be a piece of cake for them. I'll keep my eyes open for some of them. Thanks for that tip! James, this has really been messing with me. Like I said, no biggie in regards to the tumbler...it's going to have a stand-off wheel regardless as to whether it drifts or not...insurance. The only wildcard I haven't covered is whether the shafts might be racked/twisted a little bit...they don't look like they are but I haven't got down on the ground and really scoped that out. I think something is out a bit that I'm not seeing and it's just about gotta be something creating a wedge force. The round cap and reducer end differences may have something to do with it. The round cap end should weigh more than the reducer end, I would think. That might be in play. Lots of variables. I may try with more tilt, but I'm afraid it might affect the actual tumbling inside the barrel..create a deep end and shallow end. Have you ever noticed that rocks travel the length of the barrel or do they pretty well stay in one section of it? Bottom line...the barrel traveling uphill I think points to non-parallel shafts. Bottom bottom line... I'm going to have stand-off rollers so it's kind of a moot point about the creep...but it's interesting...and captbob enjoys these types of discussions.
Post by jamesp on Jan 3, 2016 11:18:56 GMT -5
The barrel walking is actually somewhat moot. Good end rollers solves that !! As toil0 mentioned, roller blade rollers or in my opinion something similar w/ball bearings. My best end roller that lasts forever is mounted high and at an angle and rolls flush on the end of the cap. Maybe there is a pic Yes, the one on the left is just a castor. But it is not in shear the way it is angled. The one on the right must get replaced every few months because of it's crappy contact point. Best thing I did was moved the end roller up high and out of the way of the pillar blocks. It is the left one that is 3 years old and has lots of pressure on it.
Post by jamesp on Jan 3, 2016 11:29:09 GMT -5
No end roller on the other side Ed. Tilt does not seem to effect tumbles. Tilt is 2-3 inches in 4 feet. The end wall of your 2 X 10 structure may serve well as a mount for a tall end roller. This greasable castor type end roller is mounted on the side wall of the 2 X 10 It just happened to fit above and between the pillar blocks.
Intheswamp
Post by Intheswamp on Jan 3, 2016 15:59:27 GMT -5
I'm going to keep my eyes open for something with ball bearings in it. Preferably something that has multiple wheels (stock for the future ). I know the roller-blade wheels are highly durable...seems there might be a pair somewhere at the shop that belonged to my nephew...I'll plunder around a bit when I get back to work. Otherwise, I'll keep my eyes peeled for "whatever". Yeah, I've got plenty of room on the wood to mount a standoff. I can see how the angled roller works a lot better...the sheer force is what's working on my dryer rollers. I think the dryer rollers would probably last for years and years if aligned properly to the barrels. The ones I'm using had been in the dryer for 4-5 years with lots of use. I had to re-felt the drum so I replaced the rollers while I had the dryer torn apart...the old ones looked about like the new ones but they had no sheer force working against them in there former/intended application.
Post by jamesp on Jan 8, 2016 4:21:27 GMT -5
I'm going to keep my eyes open for something with ball bearings in it. Preferably something that has multiple wheels (stock for the future ). I know the roller-blade wheels are highly durable...seems there might be a pair somewhere at the shop that belonged to my nephew...I'll plunder around a bit when I get back to work. Otherwise, I'll keep my eyes peeled for "whatever". Yeah, I've got plenty of room on the wood to mount a standoff. I can see how the angled roller works a lot better...the sheer force is what's working on my dryer rollers. I think the dryer rollers would probably last for years and years if aligned properly to the barrels. The ones I'm using had been in the dryer for 4-5 years with lots of use. I had to re-felt the drum so I replaced the rollers while I had the dryer torn apart...the old ones looked about like the new ones but they had no sheer force working against them in there former/intended application. That rounded end cap does better with the roller at an angle as you can see Ed. Having the roller contact further out towards the edge of the barrel reduces the shear. The shear causes friction/drag making the motor use more electricity too. The big 2 X 10 wall below makes mounting an end roller arrangement easier. Rubber wheeled industrial casters with a grease fittings ofter have ball bearings. The ones with out a swivel and a flat mounting plate are easy to adapt. Roller blade wheels as toiv0 mentioned.. Surplus Center sells flat plate ball bearing casters w/grease fitting cheap. This one $5 but big at 5 inches and heavy. Better if 3-4 inches. I have a 5 inch roller and it rolls smooth and effortless. The small tumbler has a 3 inch flat plate castor with ball bearings and grease fitting as in link below. Call Surplus Center and see if the have a ball bearing one smaller if that is better for you. www.surpluscenter.com/Casters/Casters/Plate-Casters/5x2-ALBION-RIGID-PLATE-CASTER-1-4259.axd
Post by jamesp on Jan 8, 2016 6:01:59 GMT -5
I was looking at the Covington 40 pound tumbler at $770, then shipping. Noticed it uses a 1/3 HP motor. Seems over powered to me. Comparing budgets you should be way cheaper than $770 and have two 20 # barrels which I find more flexible. And space for additional set of shafts.
Post by Deleted on Jan 8, 2016 17:34:45 GMT -5
No end roller on the other side Ed. Tilt does not seem to effect tumbles. Tilt is 2-3 inches in 4 feet. The end wall of your 2 X 10 structure may serve well as a mount for a tall end roller. This greasable castor type end roller is mounted on the side wall of the 2 X 10 It just happened to fit above and between the pillar blocks. Love seeing that orange bucket!
Post by jamesp on Jan 8, 2016 17:41:55 GMT -5
No end roller on the other side Ed. Tilt does not seem to effect tumbles. Tilt is 2-3 inches in 4 feet. The end wall of your 2 X 10 structure may serve well as a mount for a tall end roller. This greasable castor type end roller is mounted on the side wall of the 2 X 10 It just happened to fit above and between the pillar blocks. Love seeing that orange bucket! I wonder why Scott. That is the 50 pounds of SiC 30 that grinds the heck out of those stubborn agates and coral. it gets used up too fast.
