icatzaz1
Member since September 2012
Post by icatzaz1 on Jan 4, 2016 6:17:41 GMT -5
Took a break from soldering in Nov/Dec. Back now. Huge backlog but fortunately no orders, just stuff I'm doing. Just a pretty Sardonyx I ordered awhile back. Kind of a rough outline, on purpose. Precious Beryl (colorless) on sterling, although in sunlight there is a rainbow of flashes. This one was not fun at all. I had a really hard time for some reason. And there's a little goof. Not sure if I can even sell it. Been enjoying seeing everyone's new work. You guys are amazing.
Post by Deleted on Jan 4, 2016 7:13:09 GMT -5
How the hell did you do that??sorry couldn't resist
Tom
Post by Tom on Jan 4, 2016 22:01:50 GMT -5
They look good not sure I see any goof, where is it? On the right side bezel. The texture on the ring is really nice.
icatzaz1
Post by icatzaz1 on Jan 5, 2016 6:49:29 GMT -5
The goof is that I was sloppy and some oxidation solution went over the bezel and seeped under the stone. Between 5 and 5:30 you can see a dark area. The frame looks like there are few textures in that area, too, but that's just how it photographed. And yes, a little extra solder where you mentioned, Tom. Had to file it down, couldn't get all of it. But you can't see it with the naked eye.
And Dave, you cracked me up!
Tom
Post by Tom on Jan 5, 2016 8:53:18 GMT -5
Looking on big screen instead of iPad.
Hmmm, ok now I see it but from experience I know that these damb camera's of today pick out every flaw that there is, even when they can't be seen by eye. I think you should be able to pull that stone pretty easy and clean up the oxidation? I have found that type of bezel is pretty easy to pry back but I am sure no pro.
I just use the tip of an exacto knife to start a space between the stone and the bezel, then I use a really fine burnisher and work the stone loose.
If you don't mind sharing, how did you do the texture on the ring? I really like that.
metalsmith
Post by metalsmith on Jan 9, 2016 15:06:46 GMT -5
Looking on big screen instead of iPad. from experience I know that these damb camera's of today pick out every flaw that there is, even when they can't be seen by eye ^^ that! Its best to do everything bar the final finish before fitting the stone.
fireforged
Member since December 2015
Post by fireforged on Jan 9, 2016 20:01:36 GMT -5
They look good to me. Even after reading your comments about the "flaws" I don't see them as anything other than confirmation of handmade jewelry. Real handmade does not need to be flawless.
Tom
Post by Tom on Jan 9, 2016 21:13:02 GMT -5
They look good to me. Even after reading your comments about the "flaws" I don't see them as anything other than confirmation of handmade jewelry. Real handmade does not need to be flawless. I agree, tool marks and what not's add to the personality of the piece.
icatz
Member since October 2015
Post by icatz on Jan 14, 2016 9:32:59 GMT -5
I used a little hammer with a sharp end to texture the piece. I did do the final finish before setting. I got as much of the extra solder out as I could. At some point you have to say F it. As for taking it out, there are quite a few fractures and experience has taught me that I'll probably break the stone if I try. I ruined a stunning piece of Kyanite removing it. And yeah, with the naked eye, none of this stuff is visible.
Post by Fossilman on Jan 14, 2016 20:16:03 GMT -5
Nice work...............
Tom
Post by Tom on Jan 14, 2016 23:13:09 GMT -5
I used a little hammer with a sharp end to texture the piece. I did do the final finish before setting. I got as much of the extra solder out as I could. At some point you have to say F it. As for taking it out, there are quite a few fractures and experience has taught me that I'll probably break the stone if I try. I ruined a stunning piece of Kyanite removing it. And yeah, with the naked eye, none of this stuff is visible. You textured the ring with a hammer? I can see the hammering done on the pendant but the ring texture intrigues me. Today's cameras are to good lol
icatz
Post by icatz on Jan 15, 2016 18:13:40 GMT -5
LOL no Tom, I textured the pendant with a small hammer. The ring I just bashed the bottom plate with the ball peen to texture it. I had some trouble getting it even so was cutting away. The ring base texture is basically a bunch of mistakes. But it's a great stone and I'm not selling it so who cares?
Tom
Post by Tom on Jan 15, 2016 18:26:01 GMT -5
I like that "mistake" texture a lot!
