minerken
Member since August 2013
Post by minerken on Jan 21, 2016 13:49:11 GMT -5
some may find this interesting not to Nasa or telescope standards but still extreme.
Post by Pat on Jan 21, 2016 15:02:26 GMT -5
Interesting. Sometimes measurements must be perfect!
Post by Drummond Island Rocks on Jan 21, 2016 15:44:59 GMT -5
We have several 4ft x 8ft x 10" thick Starrett surface plates in our CMM checking rooms at work. They need to be certified every year to meet our customers requirements and the flatness tolerance is .002000"
Each plate weighs 7,000 pounds but we do put 25,000 pound blocks of steel on them. Neat video.
minerken
Post by minerken on Jan 21, 2016 22:15:56 GMT -5
that's some serious weight do the surface plates show any compression what are the plates mounted on?
Post by Drummond Island Rocks on Jan 22, 2016 9:42:41 GMT -5
that's some serious weight do the surface plates show any compression what are the plates mounted on? I was wrong about the size. The size is more like 5ft x 10ft x 2ft thick. I dont have pictures from the current shop I work for but here are a couple pics from the last shop I worked for. Check out the size of the granite and highly calibrated. We set plastic injection molds on those and take digital dimensions that have to be within crazy tolerances. Granite weighs about 165 lbs per cubic foot so each of these tables is about 20,000 pounds. Probably come from jamesp's neck of the woods. This is a picture of a large plastic injection mold. This one weighed about 75,000 pounds so each have when checked on that table would have been over 30,000 pounds. Chuck
Post by Fossilman on Jan 22, 2016 9:58:26 GMT -5
Thank you for sharing,interesting,yes,it was!
Member is Online
Post by jamesp on Jan 22, 2016 14:36:19 GMT -5
Need for perfection starting to make sense now. that is one big block of machined steel. Not sure where that Starrett stone comes from. Some press sections of paper machines have granite rollers that spin very fast. I think they have to take up to 3000 pounds per linear inch of pressure with out deflecting.
