Post by Deleted on Feb 14, 2016 14:21:32 GMT -5
Decided to solder this all together yesterday.took about 3 hrs. It's a beast,weighs in at 6.82 oz.it. Is all fabricated from 10 ga Sterling . Thanks for looking Dave
Post by rockjunquie on Feb 14, 2016 14:39:16 GMT -5
Nice job!!! How big are the rings? 10g + ? diameter? I would love to make something like this for my husband. I have a tradition of getting him maille. He wears them out pretty quick. It's the only jewelry he will wear and, sadly, I don't make it. But, maybe I can swing some larger rings. About how many feet did you use?
I always enjoy your posts!
fireforged
Member since December 2015
Post by fireforged on Feb 14, 2016 14:39:36 GMT -5
Very nice. I can never bring myself to put that much silver into a project. Very brave of you .
Post by Deleted on Feb 14, 2016 15:44:37 GMT -5
Thank you all for your comments.the outside diameter of the rings is 14 mm.it took about 10' of 10 ga.to make all the rings. Dave
Post by jamesp on Feb 15, 2016 7:16:11 GMT -5
Easy not in Dave's vocabulary.
Post by Deleted on Feb 15, 2016 8:30:08 GMT -5
Easy not in Dave's vocabulary. if it's not a challenge it's not worth the pursuit.lol.if the guy that was going to buy it doesn't,I won't have a problem keeping it.it was about 3 straight hours of solder,pickle,solder,pickle..... Thank you I'm digging where your going with your metal work.try some silver sheet.it forms easier than copper in my opinion. a hair more spendy Dave
metalsmith
Post by metalsmith on Feb 15, 2016 13:33:19 GMT -5
Its a lovely piece, tho I'm still not sure why you'd want to solder it...
ol3m3
Member since September 2006
Post by ol3m3 on Feb 15, 2016 13:44:05 GMT -5
did you presolder 1/3 of the rings and speed weave or did you assemble and solder as you went?
Post by Deleted on Feb 15, 2016 14:25:13 GMT -5
Its a lovely piece, tho I'm still not sure why you'd want to solder it... i don't feel it's fabricated/Smithed unless the torch is used.
Post by Deleted on Feb 15, 2016 14:25:52 GMT -5
did you presolder 1/3 of the rings and speed weave or did you assemble and solder as you went? i pick soldered every one in pairs assembling as I went
Post by Pat on Feb 15, 2016 19:51:47 GMT -5
Thank you all for your comments.the outside diameter of the rings is 14 mm.it took about 10' of 10 ga.to make all the rings. Dave WOW!!! That would be hard to do! I make Byzantine jewelry, too. However, my ID is 6.0 or 6.5mm with either 16 or 18 gauge. Lovely!
Post by Deleted on Feb 15, 2016 20:36:16 GMT -5
Thank you all for your comments.the outside diameter of the rings is 14 mm.it took about 10' of 10 ga.to make all the rings. Dave WOW!!! That would be hard to do! I make Byzantine jewelry, too. However, my ID is 6.0 or 6.5mm with either 16 or 18 gauge. Lovely! really not that bad,it's a little bit of a bugger making the jump rings,I need to make one of those jazzy jumpring maker things out of an old drill chuck
Post by Pat on Feb 15, 2016 20:56:02 GMT -5
![/quote]really not that bad,it's a little bit of a bugger making the jump rings,I need to make one of those jazzy jumpring maker things out of an old drill chuck[/quote]
My Ring coil maker is home made. Works well. It has a chuck in it. To actually cut the coiled rings, I bought the setup made by David Arens years ago when they were less expensive. Both Pepe and Rio sell them.
Post by Deleted on Feb 15, 2016 21:09:12 GMT -5
really not that bad,it's a little bit of a bugger making the jump rings,I need to make one of those jazzy jumpring maker things out of an old drill chuck[/quote] My Ring coil maker is home made. Works well. It has a chuck in it. To actually cut the coiled rings, I bought the setup made by David Arens years ago when they were less expensive. Both Pepe and Rio sell them. [/quote] can you post a pic of it?maybe give me a starting point,I've got some ideas but if someone has already figured one up I'd like to see it Dave
Post by Deleted on Feb 15, 2016 21:56:19 GMT -5
Super cool. 5.5 ounces of wire is nothing to sneeze at!!!
Nice work. Can something like that sell for $150++?
Not nosy, but curious. Don't answer if I'm being to personal.
Post by Deleted on Feb 15, 2016 23:30:37 GMT -5
Super cool. 5.5 ounces of wire is nothing to sneeze at!!! Nice work. Can something like that sell for $150++? Not nosy, but curious. Don't answer if I'm being to personal. not nosy.there was more than 150 in materials.i couldn't find jump rings that size to make the links so tight,hence the need to fabricate.i will be selling this piece for $450 Dave
Post by Deleted on Feb 15, 2016 23:45:15 GMT -5
Super cool. 5.5 ounces of wire is nothing to sneeze at!!! Nice work. Can something like that sell for $150++? Not nosy, but curious. Don't answer if I'm being to personal. not nosy.there was more than 150 in materials.i couldn't find jump rings that size to make the links so tight,hence the need to fabricate.i will be selling this piece for $450 Dave I had guessed $75 in silver and $25/hr labor. $150+++ But had no knowledge of actual costs. Still super nice. I wonder what that same piece in solid 14k would sell for!!! Over $4k in wire alone. Plus solder and time. Time is same no matter material.
Post by Pat on Feb 16, 2016 0:35:26 GMT -5
@arrowheadave. Will send photos.
Tom
Post by Tom on Feb 16, 2016 7:03:41 GMT -5
That is one beast of a chain man. I would say you need to be a large person to wear that as it is made of massive material. 14 mm links of 10G that is unreal. I like the soldered look myself (sorry metalsmith but if Soham solders then I solder, he is my new hero LOL) Dave that is a survival ring, when the zombie apocalypse happens you can use it to buy stuff, one ring at a time:)
One question did you make the T end piece or is that a purchase, it looks like it has a stamp on it so I am guessing bought?
Very nice.
Post by Deleted on Feb 16, 2016 7:42:27 GMT -5
Did you forget that I'm the stamp master?in the center of the bar its stamped STER. Then on the ends of the bar I stamped my initials D on one side T on the other.i never buy pre-fab stuf, Soham doesn't .lol Dave
