Post by Deleted on Feb 16, 2016 22:20:22 GMT -5
from this. to this. and finally this. A belcher style chain.inside tube dimension is 9.5 mm x 4 mm high before I get chastised for my sloppy solder joints,I got anxious and tumbled it to see it shine,I still need to clean up the joints.nothing a flex shaft,abrasive wheels and about an hour can't take care of.i should have snapped a pic in the light tent,sorry for fuzz and what not. for looking,stay tuned Dave
metalsmith
Post by metalsmith on Feb 17, 2016 2:10:49 GMT -5
Looking great Dave - can't wait to see this finished.
micellular
Rock fever is curable with more rocks.
Member since September 2015
Post by micellular on Feb 17, 2016 12:21:45 GMT -5
That's a lot of soldering! You have impressive patience and diligence.
icatz
Member since October 2015
Post by icatz on Feb 21, 2016 7:18:34 GMT -5
Ok, have to ask the obvious. How did you dome those small links? Looks great, btw, as we can imagine on this board...
Post by Deleted on Feb 21, 2016 7:22:59 GMT -5
Ok, have to ask the obvious. How did you dome those small links? Looks great, btw, as we can imagine on this board... thank you very much.i need to update a pic,it's 19" long now.i anealed the tubing cuts then used a dapping block.6 taps on each side Dave
icatz
Post by icatz on Feb 21, 2016 7:30:24 GMT -5
Ok, have to ask the obvious. How did you dome those small links? Looks great, btw, as we can imagine on this board... thank you very much.i need to update a pic,it's 19" long now.i anealed the tubing cuts then used a dapping block.6 taps on each side Dave Damn, I knew that was the answer. I really can't afford one of those sets but really want one. Tired of flat already! Thanks for being such a great inspiration, Dave. Whoa, that final photo is stunning!
Post by Deleted on Feb 21, 2016 8:00:03 GMT -5
thank you very much.i need to update a pic,it's 19" long now.i anealed the tubing cuts then used a dapping block.6 taps on each side Dave Damn, I knew that was the answer. I really can't afford one of those sets but really want one. Tired of flat already! Thanks for being such a great inspiration, Dave. try eBay got mine for like $60 Dave
fireforged
Member since December 2015
Post by fireforged on Feb 21, 2016 8:24:28 GMT -5
Very nice chain Dave. Looks really nice just as it is.
Post by rockjunquie on Feb 21, 2016 9:59:32 GMT -5
Very nice! That's a substantial chain.
Post by Deleted on Feb 21, 2016 15:44:52 GMT -5
Why solder every one?
Why not every other and a solid unsoldered in between?
Love your skills and herbal libations....
Post by Deleted on Feb 21, 2016 16:54:35 GMT -5
Why solder every one? Why not every other and a solid unsoldered in between? Love your skills and herbal libations.... when you dap/dome the pieces they come under tension,so when you cut them they pop open a little bit,more-so than a jumpring.to close them you must use the torch.and if I'm torching each one might as well solder each one too.herbal libations?tea?i think not.lol.that would be sacrolidge.lol Dave
Post by Deleted on Feb 21, 2016 17:03:44 GMT -5
Why solder every one? Why not every other and a solid unsoldered in between? Love your skills and herbal libations.... when you dap/dome the pieces they come under tension,so when you cut them they pop open a little bit,more-so than a jumpring.to close them you must use the torch.and if I'm torching each one might as well solder each one too.herbal libations?tea?i think not.lol.that would be sacrolidge.lol Dave So you are dapping after cutting? What happens if you never cut half, dap all, then solder half? Half the cutting, half the soldering. Libations implies beverages. Im from Los Angeles, i knew what you meant! Lol
Tom
Post by Tom on Feb 21, 2016 22:20:29 GMT -5
Why solder every one? Why not every other and a solid unsoldered in between? Love your skills and herbal libations.... LOL
icatz
Post by icatz on Feb 22, 2016 6:55:03 GMT -5
Damn, I knew that was the answer. I really can't afford one of those sets but really want one. Tired of flat already! Thanks for being such a great inspiration, Dave. try eBay got mine for like $60 Dave My "dealer" sells new sets for $65. Just can't afford till I start selling.
