djaxon
Member since February 2015
Post by djaxon on Mar 2, 2016 12:17:23 GMT -5
To the elders of the (RTH) tribe:
I have now gone through the second 100 Grit 8" SC wheel on my Frantom. I can not seem to stop gouging out the center so that it cups - concave. I have tried, especially on the current wheel, to keep the rock moving so that it is not in one place but so far the 100 g wheel and so some extent the 200 g wheel are high (and sharp) on the outer edges and concave in the center. It is frustrating because I think I am missing something about "how" to grind! Just don't know what I don't know.
I've considered a Tee shaped Diamond grinding wheel dresser. And just take off the outer sharp edges as they develop, but that seems wasteful. I hate waste, that's why I have so many boxes and cans of small scraps of stone left-overs, lol. (Wife doesn't lol : ( but tolerates my hoarding! I'm lucky.
Anyway, I am considering going to diamond wheels and just beginning to research the options. Soft / flex / hard / belts, etc....
All advice, opinion, help is GREATLY appreciated. Your input will give me direction to begin studying the choices and save me some time.
Thank you,
still a novice/tenderfoot
Don
Don
He wants you too, Malachi.
Member since December 2009
Post by Don on Mar 2, 2016 12:31:36 GMT -5
Ditch the SC wheels and replace with hard diamond plated equivalents. If you have deep pockets, get sintered diamond wheels. What does the rest of your polishing setup look like?
zarguy
Member since December 2005
Post by zarguy on Mar 2, 2016 13:09:22 GMT -5
I second Don's advice. I used SiC wheels when I was a kid. I remember concave surfaces! After I wore out my first plated diamond wheel, I bought a sintered wheel. I will probably never have to replace it. Lynn
djaxon
Post by djaxon on Mar 2, 2016 17:25:43 GMT -5
Ditch the SC wheels and replace with hard diamond plated equivalents. If you have deep pockets, get sintered diamond wheels. What does the rest of your polishing setup look like? Thanks for your input! My Frantom Combo has a 10" blade for slabbing, one 100 grit SiC and one 200 grit SiC wheel. Past that I move to a home made grind/polisher. I use Stadea velcro backed 4" pads at 30 through 6000 grit, plus two buffing pads. I get pretty good results but am working on adding a polishing set up with polish/buff wheels. I also have a 6" trim saw - home made - that I bought cheap off eBay. Recommendations are welcome! Thanks again. dj
djaxon
Post by djaxon on Mar 2, 2016 17:29:59 GMT -5
I second Don's advice. I used SiC wheels when I was a kid. I remember concave surfaces! After I wore out my first plated diamond wheel, I bought a sintered wheel. I will probably never have to replace it. Lynn Thanks much, Lynn. Do you have a recommendation for where to find the best prices on sintered wheels? dj
zarguy
Post by zarguy on Mar 2, 2016 18:36:46 GMT -5
I bought mine from Lapidarytool.com. About 5 years ago, when I bought my 60 grit 8" wheel, it was about $215 incl. shipping. I bought a 180 grit 8" wheel about a year ago & paid about $260. I think they're a bit more now. They also sell via Amazon & eBay. Inland sells them for about $450. Theirs have 3mm of diamond. The Chinese ones have 5mm. Lynn
minerken
Member since August 2013
Post by minerken on Mar 2, 2016 18:59:00 GMT -5
I used SC for years they work pretty well but you need to keep dressing them I use the T shaped diamond dressing bar from Kingsley North and it works well. After a lot of cutting I was able to control it better but never completely. With that said diamond is the way to go but you can screw up a diamond wheel by not working it across the face I use a tool rest and that seems to help me especially with the SIC.
Post by parfive on Mar 3, 2016 2:02:05 GMT -5
Nothing against your current equipment, Don, but a sintered wheel ain’t the best use of your money right now. Get as many 6” wheels as the budget allows – 80 or 100 hard wheel, 280 Nova, and on from there. The more you get done on the Frantom, the better you’ll like it.
Post by Peruano on Mar 3, 2016 12:45:29 GMT -5
I second parfive in suggesting a good, not necessarily sintered, diamond wheel in 100 and or 220. and soft wheels in high numbers or if an expand will work on the machine using sic belts or diamond belts for finer polishing. Let JSgems give you a price on diamond wheels. Tom
Post by johnjsgems on Mar 3, 2016 13:48:28 GMT -5
The Frantom combo came with a split drum on end and a big sponge to keep it wet. To put an expando on that end you would need to add a water supply and a pan and hood. I never got around to doing it to the one I had but it would be a complete unit that way. You really need two hard wheels to shape your stones. I lean toward 100 and 220 with the theory that 100 grinds a little slower than 80 but leaves less deep scratches so final shaping with 220 is faster. Since you have to remove a bearing to replace wheels best to install good hard wheels (like Diamond Pacific Galaxy)rather than cheapie bargain wheels. All will cut better and last longer than SC wheels.
djaxon
Post by djaxon on Mar 3, 2016 16:49:22 GMT -5
The Frantom combo came with a split drum on end and a big sponge to keep it wet. To put an expando on that end you would need to add a water supply and a pan and hood. I never got around to doing it to the one I had but it would be a complete unit that way. You really need two hard wheels to shape your stones. I lean toward 100 and 220 with the theory that 100 grinds a little slower than 80 but leaves less deep scratches so final shaping with 220 is faster. Since you have to remove a bearing to replace wheels best to install good hard wheels (like Diamond Pacific Galaxy)rather than cheapie bargain wheels. All will cut better and last longer than SC wheels. Thank much. I have he Frantom apart now and want to replace only the SiC 100 with Diamond Pacific Galaxy per your recommendation. Should not be a problem to replace one (100) and leave SiC 200 wheel till it wears out? Do you see any problems there? I want to get used to the Diamond and hate to waste the remains of the 200. In addition, any problems with going from 8" SiC to 6" diamond? Again, I really appreciate your advice and have put a DPG 100 in the cart. Will wait for your response. Don
Post by johnjsgems on Mar 4, 2016 20:22:24 GMT -5
How much of the 220 is left? Old safety rule was wear down to the label on side (leaves about a 6" wheel left). I've never tried mixing SC and diamond but guess it will work. Once you see how nice diamond cuts with no wheel sludge like SC you will likely save the SC wheel for blade dressing. I just boxed your order for 8" wheels but will answer anyway. You can put 6" wheels on any 8" machine as long as hoods cover adequately. Ive sold a few Titans minus wheels to pro cutters that install 6" wheels so they can work stones near bottom of wheels. Thanks for the order too.
djaxon
Post by djaxon on Mar 5, 2016 14:37:55 GMT -5
How much of the 220 is left? Old safety rule was wear down to the label on side (leaves about a 6" wheel left). I've never tried mixing SC and diamond but guess it will work. Once you see how nice diamond cuts with no wheel sludge like SC you will likely save the SC wheel for blade dressing. I just boxed your order for 8" wheels but will answer anyway. You can put 6" wheels on any 8" machine as long as hoods cover adequately. Ive sold a few Titans minus wheels to pro cutters that install 6" wheels so they can work stones near bottom of wheels. Thanks for the order too. As you know from my order, I've decided to go with both diamond wheels. The thought of "no wheel sludge" is worth the switch! Thanks for your time and advice. I have noticed a vibration in the drive lately and if that continues, with the new wheels, I will look at the possibility of new bearings. Is that reasonable? The shaft is true and I don't recall any vibration when these wheels (Rio) were new. thanks, dj
Post by johnjsgems on Mar 6, 2016 14:48:59 GMT -5
My old Frantom only vibrated with a buffing head installed. It ran very smooth with lumpy old SC wheels. See how it runs with new wheels.
djaxon
Post by djaxon on Mar 10, 2016 18:59:35 GMT -5
My old Frantom only vibrated with a buffing head installed. It ran very smooth with lumpy old SC wheels. See how it runs with new wheels. Got the two new wheels installed last night. Worked with them for about an hour. Really do like these diamond galaxy wheels from jsgemslapidary.com/ . Much less vibration with these therefore it is quieter in the shop and BEST OF ALL no wheel sludge! As I continue up the learning curve with diamond wheels, I expect to have questions and am confident that you guys will supply the answers. Thanks again John and all who donated 2 cents!
Post by Peruano on Mar 11, 2016 17:11:30 GMT -5
You won't get the grit erosion from your diamond wheels, but its still worth a rinse off of your stone when moving to the next wheel. Spin them dry, keep oil off of them, and don't gouge them with sharp edges and they will last almost forever (or at least so long you won't remember what you paid for them when its time to replace them. Enjoy the grind after you break them in with a good piece of agate (to take off the high spots). Tom
djaxon
Post by djaxon on Mar 11, 2016 17:18:21 GMT -5
You won't get the grit erosion from your diamond wheels, but its still worth a rinse off of your stone when moving to the next wheel. Spin them dry, keep oil off of them, and don't gouge them with sharp edges and they will last almost forever (or at least so long you won't remember what you paid for them when its time to replace them. Enjoy the grind after you break them in with a good piece of agate (to take off the high spots). Tom Thanks, Tom. I had not thought to rinse and spin them dry - will now! Don
