fireforged
Member since December 2015
Post by fireforged on Apr 8, 2016 15:29:19 GMT -5
Ok did a quick rock hounding trip in my brother-in-laws back yard to recover rocks that he and my dad had collected over the years. I found a number of old friends that I recognized from years ago but I also found a huge hunk (around 50-60 lbs) of something I can't identify. Here is picture what do you think. The chunk is windowed on the right side of the rock. I think the gray colors reflect the true color and the reds are from surface varnish.
Mark K
Member since April 2012
Post by Mark K on Apr 8, 2016 17:19:40 GMT -5
Looks like wonderstone to me.
zarguy
Member since December 2005
Post by zarguy on Apr 8, 2016 18:24:16 GMT -5
Maybe Wonderstone from near Fallon, Nevada. Lynn
Post by Deleted on Apr 8, 2016 22:18:22 GMT -5
Need more info. Fallon wonderstone, perhaps. Does is scratch with a knife? React with acid? Can we see more pictures? All sides... Sabre52, gemfeller
Post by Fossilman on Apr 9, 2016 11:21:26 GMT -5
Sure has some nice colors to it............
fireforged
Post by fireforged on Apr 9, 2016 12:54:53 GMT -5
Need more info. Fallon wonderstone, perhaps. Does is scratch with a knife? React with acid? Can we see more pictures? All sides... Sabre52 , gemfeller Agate scratches it but steel does not. I will have to do an acid check but doubt it will react. More pictures on the way.
Post by Deleted on Apr 9, 2016 13:04:41 GMT -5
Need more info. Fallon wonderstone, perhaps. Does is scratch with a knife? React with acid? Can we see more pictures? All sides... Sabre52 , gemfeller Agate scratches it but steel does not. I will have to do an acid check but doubt it will react. More pictures on the way. Acid not required. Scratch test rules out marble
fireforged
Post by fireforged on Apr 9, 2016 15:53:45 GMT -5
Agate scratches it but steel does not. I will have to do an acid check but doubt it will react. More pictures on the way. Acid not required. Scratch test rules out marble It has some "flowing" characteristics. Maybe some type of obsidian.
Post by Deleted on Apr 9, 2016 17:10:40 GMT -5
What happens when you whack it with a hammer?
Try to break a corner off.
Negative to obsidian. It's not glassy at all.
I'm leaning on rhyolite. Not wonderstone but rhyolite nonetheless. Betting the break is hackly.
Mark K
Post by Mark K on Apr 9, 2016 17:18:03 GMT -5
It makes a "BANG" noise.
Post by Peruano on Apr 9, 2016 17:34:49 GMT -5
I'm with rhyolite.
fireforged
Post by fireforged on Apr 9, 2016 18:24:50 GMT -5
What happens when you whack it with a hammer? Try to break a corner off. Negative to obsidian. It's not glassy at all. I'm leaning on rhyolite. Not wonderstone but rhyolite nonetheless. Betting the break is hackly. OK I hit it with a hammer and broke some chunks off. Lots of little pieces and a few 1 to 2 inch pieces. broke along the "flow" lines. Lots of fractures appeared in the rock and seems porus in spots. I guess that is what you mean by "hackly". After reading about rhyolite I am pretty sure that is what it is. Now I wonder where they found it.
fireforged
Post by fireforged on Apr 9, 2016 18:36:17 GMT -5
Hackly-I learned a new word today
