johnd
Member since May 2015
Post by johnd on Apr 16, 2016 14:28:26 GMT -5
If one mixes fluorite with concentrated muramic acid, will the resulting solution dissolve glass? Or clean gold?
I think HF has less dissociation in water than HCl- so HCl plus CaF2 should result in some HF and CaCl2- I just don't know how much.
Mark K
Member since April 2012
Post by Mark K on Apr 16, 2016 15:02:58 GMT -5
I use m uriatic acid to clean fluorite all of the time. It doe not dissolve it.
minerken
Member since August 2013
Post by minerken on Apr 16, 2016 18:35:23 GMT -5
Hydrofluoric acid is produced by treatment of the mineral fluorite (CaF2) with concentrated sulfuric acid. When combined at 265 °C, these two substances react to produce hydrogen fluoride and calcium sulfate according to the following chemical equation:
CaF2 + H2SO4 → 2 HF + CaSO4
