Post by oregon on Apr 17, 2016 23:37:35 GMT -5
I guess it's sort of a rite of passage to pull the vise back when the auto feed hasn't gotten completely tripped yet, but after one baptism, that was enough. I'm sure some of you never forget, but I get excited looking at the rock.... and am likely to forget. And it is minor-ly dangerous to have the saw start up unexpectedly. Simple way to cure this, you need a 120v relay, and a momentary push button switch, a few wires & terminals. Google a latching relay circuit. Basically the push-button momentarily energizes the relay, and the relay back feeds to keep itself closed (latched). That back feed is routed through the cutoff switch, so if the circuit is broken the power is now cut and it won't restart until the push button is pushed again. ie no start if I pull the vise back and the cutoff switch isn't completely tripped. All fits easily inside the lortone motor box up front... and no more oil showers!
Post by Rockoonz on Apr 18, 2016 0:17:36 GMT -5
I did a similar thing with the Laycock overdrives in old Volvos. The other advantage is your power switch is no longer switching the motor amperage and will probably last several lifetimes.
Post by Fossilman on Apr 18, 2016 8:53:28 GMT -5
I have a homemade saw and the switch is different that most.....So I just build a cover for my switch.. A few times I have reached over to vise it and hit the switch with a piece of clothing... Seems to work,so far......I like your idea though....
