Post by Deleted on May 4, 2016 13:32:44 GMT -5
Woot!
Post by Deleted on May 4, 2016 13:39:09 GMT -5
And here is what's in it. MH poppy from Bob luvtogrow, some random ends and cutoffs from Dan <'))))>< Fish, a few pieces from Jean rockpickerforever and some Montana's I got from Tony catmandewe. Some gifts some paid for. Thanks to everyone for your support and encouragement. jamesp! Friends all of you. I totally am happy right now. I have a sphere spinning for vegasjames. And the next project is the purple quartz vibe.
Post by Deleted on May 4, 2016 13:47:06 GMT -5
Medium:
1 cup volume #30 SiC 1 cup volume Johnny Cat clay litter(cheapest version)
Water to fill an inch below top stones.
UPDATE:
20 minutes in the clanking is much less sharp. Not the "sliding" sound Jim describes, but definitely cushioned already.
unclesoska
Member since February 2011
Post by unclesoska on May 4, 2016 13:52:10 GMT -5
What's that glowing yellow rock near the bottom- looks like it needs a Geiger counter.
Post by Deleted on May 4, 2016 13:55:47 GMT -5
What's that glowing yellow rock near the bottom- looks like it needs a Geiger counter. That is from Dan. I hope its a rock! And not bowlerite! We will know in a month when I clean out. If its still there, its a rock... Lol It is quite bright in person too. Not same color as bumblebee either. It does seem to be fluorescing in the sunlight. Overexposed when the rest of the pic is good.
Post by Deleted on May 4, 2016 13:59:23 GMT -5
chazrocker
Member since April 2016
Post by chazrocker on May 4, 2016 15:23:59 GMT -5
Very cool. You built that? What the capacity?
-Chaz
Post by Deleted on May 4, 2016 15:27:38 GMT -5
Very cool. You built that? What the capacity? -Chaz Its an MJR hunk of crap, I bought on ebay. It will wear itself out in a year, I think. Uses bushings not bearings. The first drive belt wore out in 6 months. Why? Cuz it rubs on the safety shield. Im running no safety! The barrel I made. 6" PVC parts bought at homedepot.com and shipped to the store. No freight charge! <$40 for the parts. I did not weigh it. Maybe 15# of rock.
Post by jamesp on May 4, 2016 15:35:52 GMT -5
Scott, if that is a threaded plug you may have trouble unscrewing it. Grit can wedge in the threads and make removal difficult.
No problem, you can saw the the end off and use a 4" rubber 'Fernco' cap. I love them, use a nut driver to loosen the band clamp, fast and easy.
Rock on. Nice fast speed for doing coarse grind on Mohs 7 and agates. Looks like 50-55 RPM ?? That sucker will put the grind on them. Think about ~15-25 RPM for aluminum oxides 500-1000-5000-14,000 grades, fast can work with slurry thickener in finish steps though. i can't use red clay for finishing steps, unfortunately lots of sugar for finishing. Better to have a ~15-25 RPM frame, then thickeners not needed.
Not sure if kitty litter has silicates, my raw clay does and it messes up final finish.
Finally!!
May 4, 2016 15:40:04 GMT -5
via mobile
Post by Deleted on May 4, 2016 15:40:04 GMT -5
I was careful no grit in threads.
I worried about that.
My 4" rubber cap didn't fit and could find one that did.
Yeah, it's fast. The clay mkes it quieter.
May need to build another barrel.
Post by jamesp on May 4, 2016 15:47:45 GMT -5
I was careful no grit in threads. I worried about that. My 4" rubber cap didn't fit and could find one that did. Yeah, it's fast. The clay mkes it quieter. May need to build another barrel. They have Fernco's for every size, cast iron, clay, metric, 5 inch. Go to Fernco or go to Ebay. Is that 4 inch sch 40 pipe ??
Post by jamesp on May 4, 2016 15:48:50 GMT -5
The grit gets in the threads from tumbling. Not so concerned about grit at assembly.
Finally!!
May 4, 2016 15:49:59 GMT -5
via mobile
Post by Deleted on May 4, 2016 15:49:59 GMT -5
I was careful no grit in threads. I worried about that. My 4" rubber cap didn't fit and could find one that did. Yeah, it's fast. The clay mkes it quieter. May need to build another barrel. They have Fernco's for every size, cast iron, clay, metric, 5 inch. Go to Fernco or go to Ebay. Is that 4 inch sch 40 pipe ?? No, a 6" to 4" reducer, female slip on both ends.
Post by jamesp on May 4, 2016 15:50:34 GMT -5
Looks like the 4 inch is drainage thin wall, it wears fast. Need to use sch 40 4 inch pipe. Hope I am wrong
Post by jamesp on May 4, 2016 15:52:52 GMT -5
I use about 2 cups clay for that size. No telling w/kitty litter, it may thicken a lot.
Finally!!
May 4, 2016 15:59:41 GMT -5
via mobile
Post by Deleted on May 4, 2016 15:59:41 GMT -5
82 RPM
Finally!!
May 4, 2016 16:02:24 GMT -5
via mobile
Post by Deleted on May 4, 2016 16:02:24 GMT -5
Looks like the 4 inch is drainage thin wall, it wears fast. Need to use sch 40 4 inch pipe. Hope I am wrong I emailed you a link to the reducer. It's schedule 40 fitting. But my 4" cap wouldn't go over the outside and the unit was long already. I found my old broken barrel. I'll be able to use that cap, I think.
Finally!!
May 4, 2016 16:06:25 GMT -5
via mobile
Post by Deleted on May 4, 2016 16:06:25 GMT -5
The barrel is 6" schedule 40
Post by jamesp on May 4, 2016 16:11:32 GMT -5
82 is booking for 6 inch. Do use thickener at that speed on 6 inch barrel.
Scott, next time use a bushing, not a bell reducer. The shoulders on the bell wear fast. Bushings are real thick. Shoulder wear not so much an issue.
Glue in a short stub of 4 inch pipe and the rubber cap would fit it.
Post by jamesp on May 4, 2016 16:18:27 GMT -5
Example of bell reducer shoulder wear on crappy barrels I bought from Ebay years ago. These are SDR 35 thin wall drainage pipe-useless. 2 months and they wore thru. Sch 40 a horse of a different color, but even sch 40 bell reducers wear at the shoulder. So the bushing..
