Post by oregon on May 5, 2016 23:05:48 GMT -5
Keep meaning to really give this a try, but was cleaning up today and threw one of these garden sprayers on this tumbler frame. 1 gallon seems to be just the proper size. The sprayers are cheap, but thick-walled to hold the pressure, shouldn't be hard to plug the small hole and seal the large one. (Anyone in oregon looking for a single (scott murray) or triple frame, drop me a line)
mloganrocks
Member since May 2016
Post by mloganrocks on Jun 3, 2016 2:45:42 GMT -5
Keep meaning to really give this a try, but was cleaning up today and threw one of these garden sprayers on this tumbler frame. 1 gallon seems to be just the proper size. The sprayers are cheap, but thick-walled to hold the pressure, shouldn't be hard to plug the small hole and seal the large one. (Anyone in oregon looking for a single (scott murray) or triple frame, drop me a line) I have the exact same unit (3barrel) they are 12lb barrels. Are your units for sale?
Post by jamesp on Jun 3, 2016 17:15:56 GMT -5
Great idea. Never thought about plastic pressure vessels.
zarguy
Member since December 2005
Post by zarguy on Jun 3, 2016 21:08:44 GMT -5
Great idea. You can find them at thrift stores pretty plentifull & cheap. Lynn
Post by oregon on Jun 4, 2016 21:53:39 GMT -5
I have the exact same unit (3barrel) they are 12lb barrels. Are your units for sale? Sorry, they've both found new homes... My son had fun in metal shop for a replacement. Found a nice 1/12 hp motor draws less than 2A with two full barrels and is barely warm to the touch.
mloganrocks
Post by mloganrocks on Jun 5, 2016 0:10:49 GMT -5
I have the exact same unit (3barrel) they are 12lb barrels. Are your units for sale? Sorry, they've both found new homes... My son had fun in metal shop for a replacement. Found a nice 1/12 hp motor draws less than 2A with two full barrels and is barely warm to the touch. Thats great, Im glad it worked out for you.
Post by pauls on Jul 11, 2016 17:26:22 GMT -5
I have used those sprayer bottles for years, they work a treat, the only problems are if you put in largish rocks they are difficult to remove, shake rattle and roll over a bucket usually works. Also sometimes you get a buildup of stones jammed in the neck so they aren't tumbling, open occasionaly and push them in. A bit of heat from a gas burner will melt the plastic enough to seal up the hose and pressure relief valve holes, remove the whole pump assembly and replace it with a thick rubber washer inside the screw top.
