vwfence
Post by vwfence on May 23, 2016 12:01:07 GMT -5
Has anyone tried to use diamond core bits or hole saws for cutting spheres ?
Post by Deleted on May 23, 2016 13:27:21 GMT -5
Has anyone tried to use diamond core bits or hole saws for cutting spheres ? Yes
vwfence
Post by vwfence on May 23, 2016 15:04:03 GMT -5
DO they work
Post by Deleted on May 23, 2016 15:24:28 GMT -5
Yes
Post by Deleted on May 23, 2016 15:25:35 GMT -5
Agates are hard on the segment's. To dress on the fly add some 100 grit to expose more diamond
vwfence
Post by vwfence on May 24, 2016 10:05:24 GMT -5
how big have you went Scott
Post by Deleted on May 24, 2016 13:25:39 GMT -5
how big have you went Scott 5" or so
Post by pauls on Jul 11, 2016 17:29:13 GMT -5
You can buy diamond sphere forming cups from Richon tools in China. Not a recommendation and I have never used them, just to let you know they are there.
Post by Jugglerguy on Jul 11, 2016 18:15:10 GMT -5
rattlehead
MI Rocks
Member since December 2010
Post by rattlehead on Jul 22, 2016 6:48:12 GMT -5
I've purchased from Richontools quite a bit in the past with never a problem. I never purchased cups though mainly pads and other diamond tools/supplies.. Another place I've had good luck with is Aliexpress.com and Alibaba.com. I purchase a ton from those sites when I buy in bulk. I bought some sphere motors directly thru the manufacturer from Alibaba. Even a small test order was a good deal, but you usually have to buy in bulk thru Alibaba and it can be a pain to hammer out the deals sometimes due to poor English translation...but it's worth it usually. I haven't hooked up my sphere machine motors that I bought yet, but I expect they will be okay. I fix up old guitars and build some too, and I buy a lot of my parts and tools from those sites too. If you buy things in bulk, Alibaba is a good resource, and everything is usually negotiable even minimum quantities. I bought my initial grinding cups here: www.sphereheaven.com/equipment.htmI make the polishing cups with pvc fittings and cut up diamond pads. If you buy diamond pads, I would check the richontools, aliexpress, and alibaba sites though. I may try to find a cheaper source for the diamond/copper brazing rods..... Youtube video:
