jcinpc
Member since April 2009
Post by jcinpc on Aug 25, 2016 0:11:37 GMT -5
jerrys
Member since February 2014
Post by jerrys on Aug 25, 2016 11:42:29 GMT -5
jcinpc
Post by jcinpc on Aug 25, 2016 14:34:46 GMT -5
thanks jerry,good info for later or another saw but formine I don't want a metal hood, this had a plexiglass hood and I like those better, I like to see the rock at all times, my 16in HP has a plexi hood also
Post by captbob on Aug 25, 2016 15:00:48 GMT -5
Well that's one heck of a score!! Can't beat the price either. Keep us posted on the clean up and how it runs for ya. You already have a 16" and now a 20" - sweet. What are you cutting? Are you a seller at the local rock shows? I went to the show at the Strawberry Festival hall earlier this year (I think it was this year) were you there? Are you one of the folks on Craigslist locally? Interesting link above jerrys . Those guys take the refurbishing to the limit! Prices seem kinds high though.
Post by jakesrocks on Aug 25, 2016 16:45:56 GMT -5
Be sure to rewire that puppy. Those old ones weren't grounded.
jcinpc
Post by jcinpc on Aug 25, 2016 21:03:19 GMT -5
Captbob, I was at the show, but as a customer or just walking around, traded some coral for Turquoise and all was good. I don't do Craigslist , selling nor searching, I am just a 30 yr digger/diver of coral , artifacts and fossils and kinda do my thing alone, out back in my shop . Jakesrocks, that is one of the first things I am doing beside the cleanout. the insulation around the power cord is all dry rotted and cracked, the old guy hasn't ran this since the early 1990`s. He has given me cabbing machines, kilns , tools, rough all kinds of stuff. I think he enjoys seeing his equipment being used again by someone who will appreciate them
Post by Fossilman on Aug 27, 2016 11:53:38 GMT -5
Nice set up and nice score! Nothing like bartering! Liking the plexi hood too... My saw that I just received needs a hood,this might be the ticket...
Post by Rockoonz on Aug 27, 2016 12:54:41 GMT -5
The original lids in those saws are lucite. If it's in any way repairable it will be far superior to modern acrylics that are engineered to degrade under uv light. If it's anything like my similar vintage HP14" saws you may be better with 18" blades, in mine the blade is so close to the bottom of the tub that it doesn't run enough oil, gets hot, and has to be cleaned out too often. I switched one to 12" and like it a lot better.
Post by johnjsgems on Aug 27, 2016 18:47:04 GMT -5
Likely it is an 18" saw with 20" blade. I think all their saws were two size models (12-44, 14-16, 16-18, etc. with larger size the blade is very close to back wall and bottom. 1" taller cut but 1" less horizontal.
herb
Post by herb on Sept 3, 2016 13:17:12 GMT -5
I have the same model saw (newer though). The hood it came with large cracks in several places (it was actually in a couple of pieces). I bought some fiberglass resin and matting and patched the cracks with two layers of matting and resin. Worked great! Its been about 4 years now and the patches are still holding strong. I love that the whole hood is "clear". Makes it real easy to see what is going on in there. If you use fiberglass resin, just make sure you wear gloves, work fast, and work in a really well ventilated area!
