zapins
Member since March 2016
Post by zapins on Aug 27, 2016 15:36:49 GMT -5
What chemicals and methods can I use to clean out all the brown stains from this quartz crystal? I've seen commercial miner people dunk their crystals into vats of some kind of liquid overnight on youtube videos and the crystals come out perfectly clean. Any idea on what that liquid is or how to clean it before I epoxy it back together?
Post by vegasjames on Aug 27, 2016 15:42:04 GMT -5
Many people use oxalic acid solution to remove iron stains from quartz. There is also hydrochloric acid, citric acid or CLR solutions that all remove iron as well.
Post by captbob on Aug 27, 2016 16:04:11 GMT -5
Soak them.
There is CLR which most stores carry in the cleaning supply section.
And, there is Super Iron Out. I would say this is the (much) stronger product. In the plumbing department at home depot. The vapors on this stuff are pretty serious. Use outside and keep kids & pets away.
Post by Deleted on Aug 27, 2016 17:11:17 GMT -5
Pool and spa acid is super strong... Gets the job done.
Outdoors, with gloves and eye protection, crappy old clothes....
Post by Pat on Aug 27, 2016 21:07:50 GMT -5
I use Iron Out. Grocery stores even have it. Works great.
Post by greig on Aug 29, 2016 21:38:23 GMT -5
I play around with various chemicals to see how effective they are on various rocks. So I am not a professional and am not offering advise. I will just state the following for education purposes.
At times, it depends on how patient you are, cost, fumes and disposal. With almost any of them, working outside and staying upwind is prudent. If you dilute, add the water first and not the acid. Harsh chemicals usually come with a warning to wear appropriate gloves and eye protection. Read the labels. Don't use a metal container.
With some mild acids like vinegar, they can sometimes be more effective if you add heat and/or salt. I only add salt to clean metals (eg coins or silver ore). Never heat a strong acid.
IMHO - CLR is expensive and only somewhat effective, but you can use it indoors. However, as with most chemicals/acids, immediately clean up any drips on your kitchen counter tops, as they can remove the colour. If I have time, I use vinegar for mild etching or cleaning. It may take overnight, a week or more. Real Coke is actually a mild acid too, but a bit expensive for cleaning rocks. For iron stains, standard Iron Out is pretty good. At my local stores, it is a powder in the same size and shape bottle as CLR and costs about the same - -as such, it is way more price effective than CLR for cleaning iron stains. Next up is muriatic acid from a pool/spa supply store (less cost than the big box stores sell it). I can get 4L for about the same cost as a bottle of CLR. Muriatic acid needs to be treated with care. It is fast, sometimes too fast, and it can bubble high in your container (read overflow). I start with 50:50 water:acid or less. you can always add more later. For disposal, I use it like Roundup on plants (even after it has turned to base with calcite); it will kill anything that gets sprayed. Don't mix one chemical with another - do them one at a time.
Post by greig on Aug 29, 2016 21:43:17 GMT -5
I just read my note and have one more thought. Different acids have different reactions on different rocks. So, it is never one solution for everything. If possible, test a sample first before committing your prize rock to any chemical bath. Also, keep an eye on it to ensure the right thing is happening.
zapins
Post by zapins on Aug 30, 2016 0:44:14 GMT -5
Thanks for the advice.
I got some CLR a few days ago and put the rocks in. They are very slowly getting cleaner, though the difference isn't huge. I still see bubbling from the bit of calcite lodged in the crystal so it must not be finished cleaning the rocks.
I have some super iron out coming to me in the mail so I'll try that next outside.
I have battery acid, which is sulfuric acid if I remember right and can try that out if you think it might work. I have muriatic acid (HCl) back in Connecticut (16 hour drive away at the moment) so I can't try that just yet. Unfortunately I doubt my local area sells any of that at all. They didn't even have super iron out.
Is there any way to repair or fill in the cracks in the crystal?
cassielouwho
Member since August 2016
Post by cassielouwho on Aug 30, 2016 6:00:50 GMT -5
I made a citric acid bath for my very dirty backyard rocks (calcite, and marble). It's working most surprisingly. I use 1 tbsp per 1/4 gallon. I let it sit in the sun yesterday and it cleaned that batch faster.
I have a lot of citric acid from making bath bombs in the past. I also use it in a clean cycle in my washing machine. Great stuff, that citrus
zapins
Post by zapins on Sept 3, 2016 2:08:17 GMT -5
Well I had the rocks in some CLR for about a week. It dissolved out the calcite that was stuck onto the quartz in a few places and cleaned the crystals up little. But the rust colored brown stains are still stuck in the cracks. I bathed the rocks in distilled water for a few hours to remove the CLR and then sealed them into a pickle jar with super iron out & some distilled water. Not sure what all the reviews on amazon are talking about "fumes & vapors," I didn't smell any and no gas was released from the pickle jar either. Just to be safe I put it outside. I'll check on it tomorrow, hopefully nobody steals the rocks. I wonder how long it will take to get rid of the stains (if they are iron stains at all?). I have battery acid (sulfuric acid) I can try that out next. A bit stronger than citric acid
Post by vegasjames on Sept 3, 2016 5:54:05 GMT -5
Well I had the rocks in some CLR for about a week. It dissolved out the calcite that was stuck onto the quartz in a few places and cleaned the crystals up little. But the rust colored brown stains are still stuck in the cracks. I bathed the rocks in distilled water for a few hours to remove the CLR and then sealed them into a pickle jar with super iron out & some distilled water. Not sure what all the reviews on amazon are talking about "fumes & vapors," I didn't smell any and no gas was released from the pickle jar either. Just to be safe I put it outside. I'll check on it tomorrow, hopefully nobody steals the rocks. I wonder how long it will take to get rid of the stains (if they are iron stains at all?). I have battery acid (sulfuric acid) I can try that out next. A bit stronger than citric acid I would not screw around with sulfuric acid. I work with a lot of acids and sulfuric scares me even more than nitric acid. Better to stick to the citric acid, or maybe even phosphoric acid.
metalsmith
Post by metalsmith on Sept 3, 2016 7:23:39 GMT -5
I made a citric acid bath for my very dirty backyard rocks (calcite, and marble). It's working most surprisingly. I use 1 tbsp per 1/4 gallon. I let it sit in the sun yesterday and it cleaned that batch faster. No surprise that acid is working with calcite and marble (meta-limestone / lime-muds). Acid + carbonate -> CO2 & Oxides. I'm just surprised that its not eating away the desired minerals and just leaving you with only the dirt!
cassielouwho
Post by cassielouwho on Sept 3, 2016 8:10:56 GMT -5
I made a citric acid bath for my very dirty backyard rocks (calcite, and marble). It's working most surprisingly. I use 1 tbsp per 1/4 gallon. I let it sit in the sun yesterday and it cleaned that batch faster. No surprise that acid is working with calcite and marble (meta-limestone / lime-muds). Acid + carbonate -> CO2 & Oxides. I'm just surprised that its not eating away the desired minerals and just leaving you with only the dirt! I figured if citric acid is safe enough for humans to bathe in then giving it a shot on my backyard rocks wouldn't hurt. Citric acid is used in bath bombs to create fizzies.
cassielouwho
Post by cassielouwho on Sept 3, 2016 8:12:43 GMT -5
No surprise that acid is working with calcite and marble (meta-limestone / lime-muds). Acid + carbonate -> CO2 & Oxides. I'm just surprised that its not eating away the desired minerals and just leaving you with only the dirt! I figured if citric acid is safe enough for humans to bathe in then giving it a shot on my backyard rocks wouldn't hurt. Citric acid is used in bath bombs to create fizzies. These came from that batch. They were coated with red clay.
droseraguy
Member since April 2012
Post by droseraguy on Sept 3, 2016 11:12:31 GMT -5
I used muriatic in a 3 gal pail just to the top of the quart crystal. Cleaned a bit after a few days but I swear it rounded off the points and made an even yellow stain on all the surfaces. This was a hunk of that Arkansas diamond mine stuff. Not terribly nice but then I don't think it helped it much.
zapins
Post by zapins on Sept 7, 2016 17:31:01 GMT -5
The super iron out is working well. I have it in a pickle jar with the lid on in the back of my car. It heats up during the day and as I drive around to work and back the liquid is jostled back and forth which has helped clean out most of the iron in the cracks. There is still a bit left to go but I'm hoping it should be completely cleared out by the end of the week.
Will post some photos when I'm done.
Does anyone know if it is possible to seal the cracks in some way? I know that they do this with gemstones somehow (lead glass?). Is this an easy process that you guys have used in the past or is it essentially impossible at the hobbyist level?
Post by jakesrocks on Sept 7, 2016 17:47:47 GMT -5
If that pickle jar has a metal lid, get it out of your car. Iron Out will eat right through that lid in a couple days or less.
Check your solution. If it's starting to turn yellow, remove your crystal, rinse it real good & put it in a fresh batch of solution. That yellow color is iron which will re deposit itself all over the crystal.
zapins
Post by zapins on Sept 7, 2016 23:21:06 GMT -5
I'll check the lid again tomorrow for corrosion but it has a plastic coating over the lid to protect it from the salty pickle juice so that might be buying me some time. I've also got it in a plastic tub incase of spills. The solution was water clear as of about 4 pm today, but I'll keep an eye out for yellowing. I certainly wouldn't want to redeposit the iron. That would be most unfortunate especially since it is starting to look so good.
Is there any technique I can use to fill in cracks in quartz crystals that you guys know of?
Post by Fossilman on Sept 8, 2016 9:42:15 GMT -5
Sometimes the stains you see will not come out of the rock,because it's formed right into the material....I have a few pieces like that...
Erich
Member since November 2015
Post by Erich on Sept 8, 2016 9:52:18 GMT -5
I use Oxalic acid to remove rust/iron stains, I find it works wonders and you control the strength as required. Muriatic acid I only use sparingly and with appropriate safeguards. Fumes are dangerous!!!
