Post by oregon on Sept 13, 2016 1:04:07 GMT -5
Is there a preferred direction to cut the typical brazillian agate?
Most of these look like you've started with a hemisphere and then 'smushed' it sideways. Looks to me like the layering is usually parallel to the flat face(?) so I should cut perpendicular to that. But then should I cut in the direction of the 'smush' or across that? In the first instance the slabs would be a asymmetric shape, in the latter they slabs would have a symmetrical shape. Haven't cut any yet, but seems worth thinking about before just diving in.
any websites that talk about how they're formed? They must mine them by the trainload somewhere.
Thanks for the help.
Post by Sabre52 on Sept 15, 2016 8:36:45 GMT -5
Brazilians can be a booger to get a good hold on in the vice. They do tend to have one side flatter, so most folks put the flat side down for an easier grip in the vice. If you like water line banding, this usually puts the water lines at the bottom of the slab by the flat side with the fortified parts above that. Guess you could orient them the other way for a more fortified effect if you cut through it parallel to the flatter base, but to my way of thinking, man, that's makes it exceptionally hard to secure in the vice. If you can get a hold of Lenz's " Agate Book" he has a lot of info on Brazilian agate mining, formation etc....Mel
Post by Fossilman on Sept 15, 2016 9:14:10 GMT -5
I just cut flat side down in either direction.......If I start in one direction,I stay in it,till the stone is cut.... There is no set way to cut the rock,its just easier with the flat down.... In my opinion,you do get a better over all cut too,with the designs and waterlines.....Had one that was boring to I cut it at a 27% angle and got red fire color out of it-pretty cool.......
