Post by rockjunquie on Sept 17, 2016 21:01:01 GMT -5
Howdy- The thing that comes with the genie that is supposed to help with the girdle angle, what is it called? Do you use it? I don't, mostly because I'm not even sure how to use. I think, Pat, that you mentioned that you use it. I have made it this far without it, so really, I guess, I'm just curious.
Post by Pat on Sept 17, 2016 23:46:11 GMT -5
Tela, yes, I use it. Will take photo tomorrow of it as I position it for a cab. I like it. I think it is called "cab thingie" !
Post by catmandewe on Sept 17, 2016 23:49:18 GMT -5
It is called the cab rest
Post by orrum on Sept 18, 2016 3:31:59 GMT -5
I wanna see da pic!
Post by Pat on Sept 19, 2016 17:30:20 GMT -5
Here you go. 1- position of cab rest IMG_0897 by Pat, on Flickr 2- position of cab; put good side down IMG_0898 by Pat, on Flickr 3- how I hold the cab rest. Right hand controls the cab; left hand helps IMG_0900 by Pat, on Flickr 4- cab shows the angle to help with bezel IMG_0899 by Pat, on Flickr
Post by orrum on Sept 19, 2016 17:47:36 GMT -5
Son of a gun! We have those in Q at the club. I thought it was a fancy water cab rinsing bowl!!! LOL. Duh me inbred, retarded southern Appalachian Hillbilly I reckon!
Post by rockjunquie on Sept 19, 2016 18:45:27 GMT -5
Thank you so much, Pat!!!!! I had no clue! That helps.
Post by fantastic5 on Mar 1, 2018 13:07:44 GMT -5
^^^^^X2 Pat ! Thank you for showing those pictures. When I did finally find pictures I thought it looked like it would be above the mid-line of the wheel. So it makes sense to have the good side of the cab upside down. Should be a fairly easy thing to construct too. Hmmmmm, I may give it a try.
