Post by woodman on Oct 20, 2016 16:53:55 GMT -5
Had slab come apart during the lapping process. Decided to try an epoxy to repair it.
Post by 150FromFundy on Oct 20, 2016 17:05:04 GMT -5
Epoxy? I though that was stuff was called liquid agate. No problem to convince people that slab really was wood, a long time ago.
Darryl.
Post by woodman on Oct 20, 2016 17:08:04 GMT -5
I like the liquid agate term! will use it, thanks. Oak, 10 to 15 million years ago more or less.
Post by Lapidaryrough / Jack Cole on Oct 20, 2016 17:09:23 GMT -5
i use fiber glass fine mesh
Post by woodman on Oct 20, 2016 18:13:35 GMT -5
i use fiber glass fine mesh More info needed, can't quite get the how to.
Post by Lapidaryrough / Jack Cole on Oct 20, 2016 21:08:13 GMT -5
rare to fine nice round anyplace even in the worlds largest petrified forest, Lacomb Oregon. Burnett's p wood on old sodaville rd. & rock hill. would fiber glass the face cuts of rounds. then make the next cut. Though most of the rounds he milled were over 3 - 4 ft rounds. local material from the encapsulation of the Yucatan in pack 65 million yrs ago. judge the side you like. add glass the face BEFORE the next cut ..... risen to cure is about 12 hour i use boat risen from the local shop.
should prime the surface with a thinned out mix of risen. so as to fill cracks an voids just before laying out a wet risen coated glass mat on slab.
Post by woodman on Oct 21, 2016 9:08:28 GMT -5
rare to fine nice round anyplace even in the worlds largest petrified forest, Lacomb Oregon. Burnett's p wood on old sodaville rd. & rock hill. would fiber glass the face cuts of rounds. then make the next cut. Though most of the rounds he milled were over 3 - 4 ft rounds. local material from the encapsulation of the Yucatan in pack 65 million yrs ago. judge the side you like. add glass the face BEFORE the next cut ..... risen to cure is about 12 hour i use boat risen from the local shop. should prime the surface with a thinned out mix of risen. so as to fill cracks an voids just before laying out a wet risen coated glass mat on slab. I use glass mat on some of the more delicate pieces. I have not tried glassing before making a cut tho. Some times I glue a piece of plywood to hold everything in place while making the cut. That way I am not committed to a side to finish. If I had fiberglassed this slab, I would not had to repair it. Maybe it is time for me to rethink the process and fiberglass sooner rather than later. thanks for the tips.
Post by Fossilman on Oct 21, 2016 10:06:23 GMT -5
Looks like the repair will be 100%,that is a nice slab of wood!!!!!!
