salpal48
Member since March 2015
Post by salpal48 on Oct 25, 2016 10:11:42 GMT -5
Has anyone on The forum Seen a machice Like this one. The label Is Noton Products Processing. . I have seen the base before. But This is Complete? The drum Is made of Porcelain On the out side and Crockery Through out. The Drum measure 12.5 diameter X 8.5 high. It closes as shown. The Drum empty weight Between 32-33 Pounds. Total weight Is appox 90 lb's. The machine has 13' long Rollers with a Possible 1/2 HP motor. I have not Used it yet for Rocks. because I have never seen a Drum like this. I also Tumble Cartridge cases. . . Filled with cases and Media . The weight Gets to appox 90lb's. Too heavy to lift . Enclosed Photos i1341.photobucket.com/albums/o756/salpal48/Norton%20-%201%201_zpsmsuugwhm.jpg
Post by MrMike on Oct 25, 2016 20:39:30 GMT -5
It's an industrial jar/ball mill. Uses steel, ceramic, Al or Zr oxide balls/spheres to crush material. No idea if it would work for rock tumbling, I'm sure other RTH members will know.
salpal48
Post by salpal48 on Oct 26, 2016 8:38:59 GMT -5
. My Gut opinion was the same. I ran it last night. with cartridges cases and walnut media. and Worked great. I changed drums Putting my 20'lb Craftool drum and that works well. The porcelain drum does not have a water tight seal., Not that one could not be fitted.. . When I purchased there was appoc 25lb of smooth stones inside. So someone was using it as such Sal
Post by MrMike on Oct 26, 2016 14:53:13 GMT -5
. My Gut opinion was the same. I ran it last night. with cartridges cases and walnut media. and Worked great. I changed drums Putting my 20'lb Craftool drum and that works well. The porcelain drum does not have a water tight seal., Not that one could not be fitted.. . When I purchased there was appoc 25lb of smooth stones inside. So someone was using it as such Sal Cool, that machine is well built, great score.
salpal48
Post by salpal48 on Oct 27, 2016 10:35:24 GMT -5
. I am still In the process of Cleaning . The rollers are appox 2" wide . I taking the cover off. not only there is a belt That drives the motor but There is a sproket That Is Chain Driven That drives the roller.. I was doinf some research on Norton. . there was a Norton Chemical Processing. but That's it.. It must have been made forHeavy tumbling . when Filled You need a Hoist to lift
Post by Deleted on Oct 27, 2016 12:20:28 GMT -5
