Post by oregon on Oct 28, 2016 22:38:35 GMT -5
Post by Deleted on Oct 28, 2016 23:03:08 GMT -5
Looks like a paint shaker to me... Just fooling around...
Post by quartz on Oct 29, 2016 0:13:10 GMT -5
Does it have springs on both sides? Side view would be helpful.
Post by oregon on Oct 29, 2016 1:03:33 GMT -5
Does it have springs on both sides? Side view would be helpful. Yes, the back is symmetrical to the front. Bolt with two links to the springs. Thought maybe the design was out of an old magazine or such maybe.... looking closer the upper walls of the U are slightly pinched in..
NDK
Post by NDK on Oct 29, 2016 13:53:33 GMT -5
Is it possible the hopper sits inside of a separate frame and those springs would connect it to the frame?
Post by Deleted on Oct 29, 2016 15:52:31 GMT -5
Is it possible the hopper sits inside of a separate frame and those springs would connect it to the frame? Likely. To isolate the vibration from the motor and such. The position of the motor would be at a right angle to the direction of the vibration. I cannot visualise this characteristic in this case.
Post by quartz on Oct 30, 2016 9:54:48 GMT -5
I'd agree with NDK, mounted in a separate frame. By building a frame with rigid upright on one side and sliding or pivoting upright on the other, the tension on the springs could be altered giving some control over the vibration. The springs look quite strong, but too, the amount of mass flinging around on the shaft is plenty to make it hop. Interesting basis for a project. Here I go with the unexplained line again.
