QuailRiver
Post by QuailRiver on Nov 11, 2016 20:20:07 GMT -5
Used Lortone FL20 Vibrating Lap I have a barely used Lortone FL20 Vibrating Lap for sale which is used for grinding, sanding and polishing stone slabs, geodes, thundereggs, bookends, etc.. I purchased this machine out of the estate of a deceased rockhound in Georgia. The aluminum pans measure 19-1/2" in diameter. The aluminum grit pan only appears to have been used once or twice and the aluminum polishing pan and polishing pad do not appear to have ever been used at all. Despite having had very little use, this machine was stored in a basement for over twenty years and does have a little cosmetic rust on the exterior of the steel base as can be seen in the photos. The motor runs smoothly and everything functions properly. The Lortone FL20 Vibrating Lap is no longer in production but Lortone still has a pdf file of the owner's manual their web site. www.lortone.com/pdf/FL_Instructions.pdfShipping weight is estimated at 56 lbs. The price is $375 plus shipping via Fed Ex Home Delivery. To give an idea of shipping cost, shipping via Fed Ex Home Delivery from our location in North Carolina to Atlanta, GA would be approximately $39.92. To central U.S.A., Oklahoma City, Ok would be approximately $48.98. And to ship to Los Angles, CA would cost approximately $67.41. If interested in purchasing PM me, or email me your shipping address at QuailRiver@aol.com and I will send you a Pay Pal invoice including the shipping total to your given address. Thanks for looking! Larry C.
Post by orrum on Nov 11, 2016 22:45:52 GMT -5
Nice setup!
Tousled Owl
Member since August 2011
Post by Tousled Owl on Nov 12, 2016 7:42:36 GMT -5
Hi, Larry:
PM sent - I'll take this off your hands.
Thanks, Jack
QuailRiver
Post by QuailRiver on Nov 12, 2016 13:06:23 GMT -5
Hi, Larry: PM sent - I'll take this off your hands. Thanks, Jack Great! PM received. Thank you! Larry C.
