richardh
Member since June 2016
Water jet
Nov 14, 2016 15:09:04 GMT -5
via mobile
Post by richardh on Nov 14, 2016 15:09:04 GMT -5
Does anyone know if it is possible to cut rocks with a high pressure water jet? I just saw a video on another site of a camera getting sliced in half with a 60000 psi water jet and though it might save on diamond blades.
Post by captbob on Nov 14, 2016 15:18:49 GMT -5
Google what a water jet machine costs and get back to us!
richardh
Post by richardh on Nov 14, 2016 15:54:16 GMT -5
I'm sure they are expensive but I just might have access to one.
Ok so I did a little search and they are good for cutting granite. A friend of the family has a company that makes custom steel parts and uses water jet cutters in the process.
Anyway it would be neat to see it slice through some rock.
Post by captbob on Nov 14, 2016 16:35:38 GMT -5
If you have one you can use without having to buy one, go for it! Probably going to have to figure out a way to secure the rock under the water jet. Whoever owns the machine may be your best person to ask this kinda stuff.
Post by Deleted on Nov 14, 2016 17:28:48 GMT -5
It's how the jigsaw puzzle cabochons are made.
The answer is yes!
Post by spiceman on Nov 14, 2016 20:57:53 GMT -5
You Tube shows a water jet cutting rocks. Very cool
gemfeller
Member since June 2011
Post by gemfeller on Nov 14, 2016 21:02:11 GMT -5
I knew a guy who used one to cut fire agates. He said it gave him pinpoint accuracy in opening fire bands. He cut some awesome stones. I used to see him at shows but have lost track of him in recent years. He was a little cagey about the details but apparently he had access to a machine in his machine shop.
Post by johnjsgems on Nov 15, 2016 12:42:16 GMT -5
The guy that had the rock shop in Boerne TX had a 7 or 8" state of Texas in front of his store that was about 6' tall. A local guy would cut any shape you wanted. Texas limestone but the water jet will cut pretty much anything I think.
ziggy
Post by ziggy on Nov 15, 2016 14:36:00 GMT -5
Hubby worked at a place that made machines that used water jets to cut through glass. The machines for that are around $500,000 on up. (But these were CNC controlled with big water tanks and centering devices, xyz axis cutting head moves and sensors and conveyors and stuff attached.) I believe this one also operates at 60,000 lbs.
juzwuz
Member since April 2010
Post by juzwuz on Nov 15, 2016 15:09:37 GMT -5
Water jet
Nov 17, 2016 10:44:18 GMT -5
via mobile
Post by Deleted on Nov 17, 2016 10:44:18 GMT -5
Currently $4500 for future delivery, seems like a nice little product.
