Post by HankRocks on Nov 21, 2016 11:24:06 GMT -5
Question for the Panel; Does anyone favor or ignore washing(burnishing) after final polish stage? I have have always run my rotary load for 8-10 hours in ivory soap and water in the rotary. I am not sure how to do that for the Vibrating Tumbler. Do I fill the Vibrating barrel with water to cover the rocks, how do I reduce any damage to the finished product?
Thanks for any responses.
H
Post by jamesp on Nov 21, 2016 11:33:40 GMT -5
I fill my hopper while rocks have polish with water and add a teaspoon of dishwashing soap and let it run for 10 minutes. Then do a clean out and do it again(full of water with soap) for 10-20 minutes. Sometimes a third time.
Don't think you will damage the rocks when the rocks are covered with water.
gemfeller
Member since June 2011
Post by gemfeller on Nov 21, 2016 12:04:19 GMT -5
I'm not the tumbling expert that others here are but I have some experience. I use a Minisonic and when I'm ready to do a clean-out I add a small amount of water, a small amount of Mr. Clean liquid and an ounce or so of grocery store sudsy ammonia. I let it run for half an hour or so to loosen all the mud and grit, then rinse the contents carefully in warm water after the sludge is drained. I put the stones back in the washed-out barrel, add another bit of Mr. Clean and run another half hour or so followed by another warm water wash. The stones come out glistening with no residue.
ChicagoDave
Member since June 2016
Post by ChicagoDave on Nov 21, 2016 13:41:26 GMT -5
I clean my Lot-O out after final polish and rinse everything off. Add everything back to the Lot-O with 2 tablespoons of Borax and a capful of water. I let this run 4-5 hours. I haven't seen this cause any damage.
Post by captbob on Nov 21, 2016 15:03:50 GMT -5
Question for the Panel; Does anyone favor or ignore washing(burnishing) after final polish stage? Disclaimer: I'm a rotary guy. I usually do the burnish step after polish, but I'm not sure why. Habit I guess. On every load, a pull a couple rocks out after polish and leave out of the burnish run. I have yet to see an appreciable difference between the rocks that get run through a burnish cycle and those that were pulled aside. Try this (pull a few rocks) when you finish a polish cycle and see if the burnish seems to make a difference for you.
richardh
Post by richardh on Nov 21, 2016 15:07:33 GMT -5
Question for the Panel; Does anyone favor or ignore washing(burnishing) after final polish stage? Disclaimer: I'm a rotary guy. I usually do the burnish step after polish, but I'm not sure why. Habit I guess. On every load, a pull a couple rocks out after polish and leave out of the burnish run. I have yet to see an appreciable difference between the rocks that get run through a burnish cycle and those that were pulled aside. Try this (pull a few rocks) when you finish a polish cycle and see if the burnish seems to make a difference for you. This has been exactly my experience so far, also 100% rotary.
Post by wigglinrocks on Nov 22, 2016 0:29:54 GMT -5
In the Gy-Roc model A , at the end of the polish stage I add a squirt of Dawn dish soap and a couple cups of water . Run that for 10 or so minutes , dump and rinse real well , reload rocks in bowl with 3-4 cups of water and 1 tbs borax and run for 1/2 hour or so to wash , dump and rinse real well again . Then I do a burnish run with 1 cup water and 2 tbs borax and let em wiggle for 3 hours , dump and rinse again . If the water is cloudy , which is most times , I load them back up with 3-4 cups water and run again for 10-15 minutes , dump and rinse again . The water usually comes out clear by then . Are my methods right or wrong I don't know . But it seems to me the burnish must do something right if the water comes out cloudy after the burnish . Noticeable difference in the rocks ? Sometimes I think yes , sometimes no . Try the burnish and try without . What it comes down to is , you are who you are trying to please . When I started tumbling ,I was happy with the shiny rocks that came out . But after seeing the veterans pics on here I knew I had a lot to learn . I don't try out do someone else , I try to out do what I did last time .
dottyt
Member since July 2016
Post by dottyt on Nov 22, 2016 1:38:42 GMT -5
Disclaimer: I'm a rotary guy. I usually do the burnish step after polish, but I'm not sure why. Habit I guess. On every load, a pull a couple rocks out after polish and leave out of the burnish run. I have yet to see an appreciable difference between the rocks that get run through a burnish cycle and those that were pulled aside. Try this (pull a few rocks) when you finish a polish cycle and see if the burnish seems to make a difference for you. This has been exactly my experience so far, also 100% rotary. Me three. I bought some borax, but found it didn't really clean the rocks and any better and stopped using it. I am rotary only too. I was hot to get a Lot-O, but I have had Stage 1 going for over 7 days without a clean out and new grit several times due to a busy schedule. So now I am wondering how I could possibly check a vibe every 12 hours....
