Post by HankRocks on Dec 4, 2016 11:21:01 GMT -5
How far past the bottom tip of the Diamond Blade should the oil rise. I just poured all 5 gallons of the new oil I had in a just cleaned 24 inch Saw and the oil just touches the tip? 1/4"? 1/2"?
Thanks
H
Post by jamesp on Dec 4, 2016 11:49:14 GMT -5
I do about 1/2 to 5/8".
Post by HankRocks on Dec 4, 2016 12:01:31 GMT -5
I suppose I will need to order a couple more gallons. Using the UltraCruz Mineral Oil Light.
Thanks
Post by captbob on Dec 4, 2016 12:20:15 GMT -5
Some add bricks or the like to raise the oil level. Kinda like a brick in the toilet tank to bring up the water level to the needed height without having to use the normal amount of water.
I haven't done this, but read about such here.
Post by HankRocks on Dec 4, 2016 12:31:24 GMT -5
I like that idea. Will take two or three, clean them off good and then place in the far corner of the tank.
Thanks
H
Post by captbob on Dec 4, 2016 12:35:51 GMT -5
If I went that route, I'd probably go to Home Depot (wherever) and buy a paver or two, larger than a brick. Thinking the extra weight may help make sure it never moves. But I bet that bricks would be just fine.
Post by HankRocks on Dec 4, 2016 12:39:58 GMT -5
Have a few spare 6 X 12 by 2 inch depth cinder block type. One of those should work, nice and heavy and not likely to move.
Thanks
Post by Tommy on Dec 4, 2016 12:43:51 GMT -5
I've done the bricks thing and it seemed like a great idea to me and it works right up until cleanout time. Not the end of the world but it definitely added to the generally sh***y experience of cleaning the saw and gives you more things that have to be cleaned - or not. I think mine went straight into the landfill garbage. In hindsight I would place the bricks on their edges to provide more leverage when trying to separate them from the muckymuck they became glued in.
Good call on the choice of SCBT oil. I've ordered from them three times now with perfect success.
Post by HankRocks on Dec 4, 2016 13:07:33 GMT -5
The flat block I just pulled out from behind the garage already had a weathered coat of paint, maybe I will re-paint with several coats to sort of seal it from oil absorption(maybe) and then place it on a couple of very flat and thin sticks like tongue depressors making it a bit easier to remove during clean-out.
Just cleaned my 24 inch saw yesterday. What a mess!! it took almost 3 hours and some old clothes straight to the trash can. Now I just need to let to old oil settle out and take it down to my local mechanic for disposal.
H
Post by glennz01 on Dec 4, 2016 13:16:46 GMT -5
I've done the bricks thing and it seemed like a great idea to me and it works right up until cleanout time. Not the end of the world but it definitely added to the generally sh***y experience of cleaning the saw and gives you more things that have to be cleaned - or not. I think mine went straight into the landfill garbage. In hindsight I would place the bricks on their edges to provide more leverage when trying to separate them from the muckymuck they became glued in. Good call on the choice of SCBT oil. I've ordered from them three times now with perfect success. Can ya send me a link?
Post by Tommy on Dec 4, 2016 13:22:38 GMT -5
UltraCruz Mineral OilIt's a great deal in the US with free shipping over $50. Not sure what the freight to Canada would do to you.
Post by captbob on Dec 4, 2016 13:53:10 GMT -5
Glenn is in Alaska. Probably still expensive to ship there.
Hey Glenn - what/where is your new avatar picture?
Post by glennz01 on Dec 4, 2016 20:52:13 GMT -5
Glenn is in Alaska. Probably still expensive to ship there. Hey Glenn - what/where is your new avatar picture? What you can't see is the few thousand bugs... and the bugs weren't that bad considering
mikeinsjc
Member since June 2010
Post by mikeinsjc on Dec 8, 2016 1:06:12 GMT -5
I have two HP 24's and have the blades about an inch into the oil. Unless you are in the habit of regularly looking at the blade, more oil is better than less.
Post by DirtCleaner on Jan 3, 2017 22:10:29 GMT -5
I see you are letting the oil settle out. that does work well but it does take time. I also run mine through a complicated filter system. A paper bag from a grocery store. Patience is key as it can take a couple of weeks to get 90% of the recoverable oil out. I dump that right back in the saw and then keep filtering the rest continually. By the time I am done with it the bag goes right in the trash.
