tropidale
Member since October 2016
Post by tropidale on Dec 5, 2016 19:00:05 GMT -5
Hi all, I am planning to buy a vibe tumbler to finish my cabbing preforms, mainly the polishing, and I have some questions. The choice is between the Thumler Ultra vibe 10 MB and the Lot-O. I hear rave reviews about the shine from the Lot-O but am put off by the unportability once it is glued to a cinder block, as well as the need to fill a depression in the bottom of the bowl with glue. Also, it seems that there is a larger company behind the Thumlers than the Lot-O from a quality control and customer service perspective. I am a little spoiled being a professional buyer for a large company. We're a fussy lot.... So I am leaning toward the Thumler. Will it also give a great shine, or is the Lot-O significantly better? I love shiny things, but if they are both reasonable similar in results, I'd go for the Thumler. Anybody have a strong case for Lot-O over Thumler? (or "Thumper" as my spell check keeps insisting..... .....) Thanks for any advice. Dale
Post by wigglinrocks on Dec 5, 2016 19:51:24 GMT -5
I know this isn't what you asked for , but I really like the Gy-Roc vibes . Portable , 2 speed , easy cleaning , and lower cost bowls . I had some questions when I first got mine , called the company and the owner spent an hour answering all my questions . Also gave me 3 phone numbers , ( day , evening , and cell number ) to contact him if I had any problems or questions . That being said , there seems to be a lot more lot-o users here than other vibes . Also a bunch of world class tumblers who are very generous with help , tips and recipes .
tropidale
Post by tropidale on Dec 5, 2016 23:24:01 GMT -5
Thanks, Rich. I took a look at the Gy-Roc as well but it was pushing my budget a bit too much. Truth is, my original plan was a $100 rotary so I am already well beyond that and still have the grit etc to add to the list. Thanks again for your input.
Dale
monna0000
Member since May 2016
Post by monna0000 on Dec 6, 2016 0:56:26 GMT -5
Hi, I don't know the different Quality for the 2 vibes, but take into consideration what you plan to use for stage one. I recently bought a uv-10 but soon reliazed i need to use my "regular" thumbler for stage one and since my thumbler is only 2lb it takes forever before I have enough to feed my Vibe. So if you have a small thumbler I would go with the lot-O
