ryan
Member since October 2016
Post by ryan on Dec 9, 2016 0:28:56 GMT -5
flic.kr/p/NMujrZSome kind of jasper? Got a basketball sized chunk not sure where it came from
Post by Tommy on Dec 9, 2016 9:59:03 GMT -5
Is the yellowish area translucent or opaque? What's the hardness like? have you tried scratching it with a knife?
ryan
jasper?
Dec 9, 2016 11:34:59 GMT -5
Post by ryan on Dec 9, 2016 11:34:59 GMT -5
Is the yellowish area translucent or opaque? What's the hardness like? have you tried scratching it with a knife? Yo tommy thanks for the help! The yellowish area is only opaque in a couple small areas And the knife test only left a silver line that I wiped off easily leaving no mark at all flic.kr/p/Q3oNGHHere's the stone with water
jasper?
Dec 9, 2016 11:35:27 GMT -5
via mobile
Tommy likes this
Post by Deleted on Dec 9, 2016 11:35:27 GMT -5
Looks to me like calcite (as Tommy is alluding to) or agate in matrix. ETA simulpost, sorry
jasper?
Dec 9, 2016 13:15:28 GMT -5
Post by Tommy on Dec 9, 2016 13:15:28 GMT -5
The yellowish area is only opaque in a couple small areas Well that answers your title question about jasper - jasper is opaque by definition although I see a lot of stuff on the internet called jasper when it's not. Maybe others will chime in on the hardness - could it be opalite? Never seen that color but I'm sure there's a lot I haven't seen.
jasper?
Dec 9, 2016 14:22:58 GMT -5
via mobile
Post by Deleted on Dec 9, 2016 14:22:58 GMT -5
Yeah, that is a weird color. Any chance you can make a daylight image?
Where was it found. Not good coords but zip code or something close is fine.
ryan
jasper?
Dec 9, 2016 16:19:14 GMT -5
Post by ryan on Dec 9, 2016 16:19:14 GMT -5
Yeah, that is a weird color. Any chance you can make a daylight image? Where was it found. Not good coords but zip code or something close is fine. It's not sunny but overcast see if this pic helps n no I don't know where it came from my ol man found it years ago most likely from colorado though flic.kr/p/PPKac5
jasper?
Dec 9, 2016 16:49:26 GMT -5
Post by victor1941 on Dec 9, 2016 16:49:26 GMT -5
The fracturing pattern looks like opalite in the last picture.
jasper?
Dec 9, 2016 18:00:52 GMT -5
via mobile
Post by Deleted on Dec 9, 2016 18:00:52 GMT -5
Yeah, that is a weird color. Any chance you can make a daylight image? Where was it found. Not good coords but zip code or something close is fine. It's not sunny but overcast see if this pic helps n no I don't know where it came from my ol man found it years ago most likely from colorado though flic.kr/p/PPKac5Put your two images side by side and see what I was looking for. Cloudy lights still sunlight. Color balance is a slam dunk that way. The yellow in sunlight pic corresponds with an iron salt. So, perhaps opal, opaline, pastelite..... I'm at the end of my knowledge. Best wishes!!
jasper?
Dec 9, 2016 23:32:25 GMT -5
via mobile
Post by washingtonrocks on Dec 9, 2016 23:32:25 GMT -5
Looks like garnet again, but in some weird sort of matrix. Maybe marble?
jasper?
Dec 18, 2016 12:29:36 GMT -5
via mobile
Post by Deleted on Dec 18, 2016 12:29:36 GMT -5
Looks like garnet again, but in some weird sort of matrix. Maybe marble? The pink is the matrix. The yellow is the subject in question. It doesn't scratch with a steel knife. 5 or harder.
