salpal48
Member since March 2015
Post by salpal48 on Dec 13, 2016 14:00:45 GMT -5
I went to a Flea market last weekend a Seller had a Few 6 lb Lortone Rubber drums. . They were so encrusted with dried Grit. Does anyone have any way to Remove it. fairly Easy I treid soaking them with small amounts of Results
Post by captbob on Dec 13, 2016 14:09:37 GMT -5
Grit inside or out?
If inside, run a coarse grit load of rocks. Bet that takes the dried grit off.
Outside. hmmm... Take then to a spray wand type car wash maybe? (If you don't have a pressure washer at home) Sandpaper? Wire brush, like your outdoor grill brush?
salpal48
Post by salpal48 on Dec 13, 2016 14:55:48 GMT -5
Thanks Seems to be Getting more difficult By the Day. I.m currently cleaning the inside with Stainless Steel pins. I am wondering if I can Tumble The Drum outside In a Larger Drum
Post by wigglinrocks on Dec 13, 2016 14:57:26 GMT -5
Grit inside or out? If inside, run a coarse grit load of rocks. Bet that takes the dried grit off. Outside. hmmm... Take then to a spray wand type car wash maybe? (If you don't have a pressure washer at home) Sandpaper? Wire brush, like your outdoor grill brush? I agree , run a load of junk rock overnight . I bought a used QT 66 awhile back , one barrel had a bunch of dried crap in it . I just loaded it with rough rock and a little water , ran for maybe an hour and it came out fairly clean . If you are just going to use them for roughing , not much of a problem .
Post by glennz01 on Dec 13, 2016 16:21:37 GMT -5
pics help
salpal48
Post by salpal48 on Dec 13, 2016 18:19:03 GMT -5
Never took Pictures Before and after. Well i think The drums were wrapped in duck tape or something and The grit was stuck to it. I plaeed the entire drums in My parts washer and I use ZEP Citrus cleaner straight . In less than an Hour . I noticed It devolving. They are currently in the washer now and will keey overnight. This stuff takes off everything sal
Post by glennz01 on Dec 14, 2016 3:21:33 GMT -5
Never took Pictures Before and after. Well i think The drums were wrapped in duck tape or something and The grit was stuck to it. I plaeed the entire drums in My parts washer and I use ZEP Citrus cleaner straight . In less than an Hour . I noticed It devolving. They are currently in the washer now and will keey overnight. This stuff takes off everything sal if the outside had ducktape on, to remove the stickyness use a little bit of mineral spirits on a paper towell and it will come off
Post by greig on Dec 14, 2016 12:58:32 GMT -5
If that does not work, perhaps try acetone to remove the glue.
salpal48
Post by salpal48 on Dec 14, 2016 16:52:49 GMT -5
Thanks for everyones help. The Zep Degreaser worked Ok overnight Sal
