Post by jamesp on Dec 14, 2016 8:50:13 GMT -5
Looking at the heavy concrete base of a Lot-O. Has to do with it's ability to function properly by design.
I stuck 2 layers of cardboard under the right side of my Viking vibe and it altered the mixing substantially. I had tried tilting it and it had little effect. Seems the softer padding under the right side is the cause for the change. Easier than putzing with the counterbalances.
Post by Fossilman on Dec 14, 2016 10:18:55 GMT -5
My next purchase is going to be a Vibe tumbler..........Looking at options..
Post by jamesp on Dec 14, 2016 10:29:32 GMT -5
My next purchase is going to be a Vibe tumbler..........Looking at options.. The only way to go Michael. Always spent 4 weeks 220-500-1000-polish in the barrel and a bunch of abrasives. Vibe- slap AO 80 to darn near polish in 2 days, 14,000 for a day to wet shine. 3 days vs 4 weeks Get you a Used Viking and a Lot-O.
Post by captbob on Dec 14, 2016 10:37:08 GMT -5
Get you a Used Viking and a Lot-O. Easier to find hen's teeth.
Post by jamesp on Dec 14, 2016 10:39:51 GMT -5
Get you a Used Viking and a Lot-O. Easier to find hen's teeth. I know you watch Ebay. If you said it it's true.
panamark
Member since September 2012
Post by panamark on Dec 14, 2016 14:02:08 GMT -5
Looking at the heavy concrete base of a Lot-O. Has to do with it's ability to function properly by design. I stuck 2 layers of cardboard under the right side of my Viking vibe and it altered the mixing substantially. I had tried tilting it and it had little effect. Seems the softer padding under the right side is the cause for the change. Easier than putzing with the counterbalances. Interesting. I guess the dampening of the spring on that side was more effective than tilting. On my vibe I can grab one side to dampen and the rocks start climbing the other side pretty quickly. Some complicated physics going on in a vibe
Post by jamesp on Dec 14, 2016 15:08:14 GMT -5
Looking at the heavy concrete base of a Lot-O. Has to do with it's ability to function properly by design. I stuck 2 layers of cardboard under the right side of my Viking vibe and it altered the mixing substantially. I had tried tilting it and it had little effect. Seems the softer padding under the right side is the cause for the change. Easier than putzing with the counterbalances. Interesting. I guess the dampening of the spring on that side was more effective than tilting. On my vibe I can grab one side to dampen and the rocks start climbing the other side pretty quickly. Some complicated physics going on in a vibe Exactly as you put it Mark. Physics and some.
Post by Deleted on Dec 14, 2016 20:37:55 GMT -5
Thank you. Interesting knowledge.
Post by jamesp on Dec 14, 2016 20:43:35 GMT -5
Thank you. Interesting knowledge. It runs on a couple of 2 X 6's on a gravel floor. Not a consistent platform.
mikeyrocks
Member since November 2014
Post by mikeyrocks on Dec 14, 2016 21:00:06 GMT -5
Since the topic is the Viking and how it sits ... I have a question. Anyone have suggestions or ideas relating to replacing the original rubber feet on the Vikings. Me ... I'm amazingly lucky .... I've accumulated 4 of them over the years. Just putting them to work after, redoing cracked brittle wiring, and some worn springs. Any recommendations on spring replacements? I have one large barrel and I have to find the old post on making the large barrels out of a old propane tank. Thanks all and have fun with your Vikings and Lot O's.
Post by Fossilman on Dec 14, 2016 22:06:49 GMT -5
Get you a Used Viking and a Lot-O. Easier to find hen's teeth. I know where a few are setting......Probably pick up one of them....
Post by jamesp on Dec 14, 2016 23:10:01 GMT -5
Easier to find hen's teeth. I know where a few are setting......Probably pick up one of them.... Get it Michael.
Post by jamesp on Dec 14, 2016 23:10:58 GMT -5
Since the topic is the Viking and how it sits ... I have a question. Anyone have suggestions or ideas relating to replacing the original rubber feet on the Vikings. Me ... I'm amazingly lucky .... I've accumulated 4 of them over the years. Just putting them to work after, redoing cracked brittle wiring, and some worn springs. Any recommendations on spring replacements? I have one large barrel and I have to find the old post on making the large barrels out of a old propane tank. Thanks all and have fun with your Vikings and Lot O's. MrP made that barrel.
Post by quartz on Dec 14, 2016 23:50:37 GMT -5
Since the topic is the Viking and how it sits ... I have a question. Anyone have suggestions or ideas relating to replacing the original rubber feet on the Vikings. Me ... I'm amazingly lucky .... I've accumulated 4 of them over the years. Just putting them to work after, redoing cracked brittle wiring, and some worn springs. Any recommendations on spring replacements? I have one large barrel and I have to find the old post on making the large barrels out of a old propane tank. Thanks all and have fun with your Vikings and Lot O's. mikeyrocks, I got some replacement feet for my Viking at my local John Deere dealer, they are larger in diameter, were sub'd for the ones I actually wanted, but work fine. Their parts book has a big selection of feet.
Post by jamesp on Dec 15, 2016 6:02:36 GMT -5
Mine only has three feet. John Deere -thanks quartz.
Post by fantastic5 on Dec 15, 2016 9:38:26 GMT -5
Get you a Used Viking and a Lot-O. Easier to find hen's teeth. Whenever I see jamesp post about the Viking I kick myself for passing on it. But it is certainly getting a work out and I can vicariously enjoy it through his posts. The way my life has been for the past two years it would just be collecting dust with the Lot-O. Almost done with the remodel from hell. Now just clean the garage and get rid of everything we kept, but didn't put back in the house and I'll be back
Post by captbob on Dec 15, 2016 9:59:26 GMT -5
woot! An Ann flyby! Hope to see ya back here soon. Merry Christmas to ya. What is this "and get rid of everything we kept, but didn't put back in the house" you speak of? People get rid of stuff??!
Post by jamesp on Dec 15, 2016 13:47:34 GMT -5
fantastic5 Want to sell that Lot-O to help clean out ? Kidding You are missed. Nothing has changed here. Purdy rocks and politics. Come by more often. Merry Christmas
Post by toiv0 on Feb 7, 2020 8:39:57 GMT -5
jamesp just rebuilding an old Viking with as 35 lb barrel. It has a crack in the lining. I looked for your post that you made one from a pipe. I believe you then sectored it off. Any pictures and or dementions? I also have one with the 2 six lb barrels I haven't looked at yet.I seen some one made a barrel out of a propane tank? Any thought on redlining the 35 lb barrel.
Post by joshuamcduffie on Feb 7, 2020 8:53:32 GMT -5
My next purchase is going to be a Vibe tumbler..........Looking at options.. The only way to go Michael. Always spent 4 weeks 220-500-1000-polish in the barrel and a bunch of abrasives. Vibe- slap AO 80 to darn near polish in 2 days, 14,000 for a day to wet shine. 3 days vs 4 weeks Get you a Used Viking and a Lot-O. Easier said than done, I think. If you see any for sale used, let me know.
